Community-Contributed Guide
Introduction
Go to step 1 ↓The text below describes how to open the Canon EOS M and remove the screen.
Tools
Remove the carrying strap
Remove the lens and, if available, attach a protective cover to the lens mount instead.
Remove all outer screws. However, not from the lens mount.
If you haven't already done so, remove the screw behind the port cover.
Then remove both side panels.
Fold up the two black clips next to the screen.
Carefully remove the screen.
It is clipped into a base and may have to be moved back and forth for this purpose.
Work the steps in reverse order to reassemble your device.
Special thanks to these translators:
100%
HelloMacOS is helping us fix the world! Want to contribute?
Start translating ›
1 Guide Comment
Preciso de uma placa mãe para Canon EOS M.
Tem alguma a venda?
