Canon EOS Digital Rebel (300D) Front Casing Replacement
  1. Canon EOS Digital Rebel (300D) Front Casing Replacement, Remove the front screws: step 1, image 1 of 1
    • Remove the two 7mm philips screws from the front casing.
  2. Canon EOS Digital Rebel (300D) Front Casing Replacement, Remove bottom screws: step 2, image 1 of 1
    • Remove the three 1/8" philips screws from the bottom.
    • Remove the single 3/16" philips screw from the bottom.
  3. Canon EOS Digital Rebel (300D) Front Casing Replacement, Remove the right side screws: step 3, image 1 of 1
    • Remove the two 1/8" philip screws from the right side of the front casing.
  4. Canon EOS Digital Rebel (300D) Front Casing Replacement, Remove battery door: step 4, image 1 of 2 Canon EOS Digital Rebel (300D) Front Casing Replacement, Remove battery door: step 4, image 2 of 2
    • Locate the lock of the battery door and pull it for allowing the door to be removed.
    • Remove the battery door.
  5. Canon EOS Digital Rebel (300D) Front Casing Replacement, Remove the battery door hinge mount: step 5, image 1 of 1
    • Remove the two 1/8" philips screws from the hinge mount.
    • Take out the door hinge mount.
  6. Canon EOS Digital Rebel (300D) Front Casing Replacement, Remove internal screws: step 6, image 1 of 2 Canon EOS Digital Rebel (300D) Front Casing Replacement, Remove internal screws: step 6, image 2 of 2
    • Remove the screw holding the black cap which covers access holes to the screws holding the front casing to the battery compartment.
    • Remove the black cap pulling it to the right.
    • Remove the two 3/16" philips screws.
Claudio Felix
833 Reputation
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 6
All Time: 937
