Canon EOS 70D Interface Cover Replacement
    1. Canon EOS 70D Interface Cover Replacement, Interface Cover: step 1, image 1 of 2 Canon EOS 70D Interface Cover Replacement, Interface Cover: step 1, image 2 of 2
      • Before beginning, remove the battery and SD card from the camera.
      • Using your thumbs, push up on the eyepiece to remove it.
      • Remove the battery door.
      • Open the battery door to about a 35° angle.
      • Pull the battery door straight outwards.
      Ask FixBot
    2. Canon EOS 70D Interface Cover Replacement: step 2, image 1 of 3 Canon EOS 70D Interface Cover Replacement: step 2, image 2 of 3 Canon EOS 70D Interface Cover Replacement: step 2, image 3 of 3
      • Using a plastic spudger tool, peel off the rubber grip on the left side of the camera.
      • Underneath where the rubber grip was, remove the following screws:
      • Three M1.7x5.5mm Phillips #000 screws
      • Pry off the plastic interface cover.
      • Use a plastic opening tool if a fingernail doesn't work.
      Ask FixBot
Attached Documents
Zephosk
6,197 Reputation
39 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 28
Past 30 Days: 69
All Time: 423
