Canon EOS 70D Front Cover Replacement
    1. Canon EOS 70D Front Cover Replacement, Interface Cover: step 1, image 1 of 2 Canon EOS 70D Front Cover Replacement, Interface Cover: step 1, image 2 of 2
      • Before beginning, remove the battery and SD card from the camera.
      • Using your thumbs, push up on the eyepiece to remove it.
      • Remove the battery door.
      • Open the battery door to about a 35° angle.
      • Pull the battery door straight outwards.
      Ask FixBot
    2. Canon EOS 70D Front Cover Replacement: step 2, image 1 of 3 Canon EOS 70D Front Cover Replacement: step 2, image 2 of 3 Canon EOS 70D Front Cover Replacement: step 2, image 3 of 3
      • Using a plastic spudger tool, peel off the rubber grip on the left side of the camera.
      • Underneath where the rubber grip was, remove the following screws:
      • Three M1.7x5.5mm Phillips #000 screws
      • Pry off the plastic interface cover.
      • Use a plastic opening tool if a fingernail doesn't work.
      Ask FixBot
    1. Canon EOS 70D Front Cover Replacement, Back Cover: step 3, image 1 of 3 Canon EOS 70D Front Cover Replacement, Back Cover: step 3, image 2 of 3 Canon EOS 70D Front Cover Replacement, Back Cover: step 3, image 3 of 3
      • Using the plastic spudger tool, peel back the rubber grip on the right side of the camera to expose the screws.
      • Remove the following screws underneath the right rubber grip:
      • One M1.7x3.0mm JIS #000 screw
      • One M1.7x3.5mm JIS #000 screw
      • On the back of the camera, remove the following screws:
      • Two M1.7x5.5mm JIS #000 screws
      Ask FixBot
    2. Canon EOS 70D Front Cover Replacement: step 4, image 1 of 3 Canon EOS 70D Front Cover Replacement: step 4, image 2 of 3 Canon EOS 70D Front Cover Replacement: step 4, image 3 of 3
      • On the bottom of the camera, remove the following screws:
      • Three M1.7x3.0mm JIS #000 screws
      • Slightly lift up the back cover from the camera, using a plastic spudger or opening tool as needed.
      • Be very careful when lifting the back cover up, there are still two fragile cables attached to it.
      • You can lift the back cover towards the bottom of the camera to get better access to remove the cables.
      Ask FixBot
    3. Canon EOS 70D Front Cover Replacement: step 5, image 1 of 3 Canon EOS 70D Front Cover Replacement: step 5, image 2 of 3 Canon EOS 70D Front Cover Replacement: step 5, image 3 of 3
      • With a plastic spudger tool, gently lift up on the black locking tab on the ribbon cable connector.
      • Once the locking tab is lifted up, you can carefully pull out the ribbon cable.
      • Use the plastic spudger to gently pry off the other cable connecting the back cover to the camera.
      • The connector tab sticks out slightly on each end of the connector, which gives you a good spot to pry the connector off.
      • With both of the cables disconnected, you can finish lifting off the back cover from the camera.
      Ask FixBot
    1. Canon EOS 70D Front Cover Replacement, Front Cover: step 6, image 1 of 3 Canon EOS 70D Front Cover Replacement, Front Cover: step 6, image 2 of 3 Canon EOS 70D Front Cover Replacement, Front Cover: step 6, image 3 of 3
      • Peel the right rubber grip off the rest of the way.
      • On the front of the camera, remove the following screws:
      • Two M1.7x5.0mm Phillips #000 screws
      • One M1.7x4.5mm Phillips #000 screw
      • Two M1.7x6.0mm JIS #000 screws
      • On the right side of the camera, remove the following screws:
      Ask FixBot
    2. Canon EOS 70D Front Cover Replacement: step 7, image 1 of 3 Canon EOS 70D Front Cover Replacement: step 7, image 2 of 3 Canon EOS 70D Front Cover Replacement: step 7, image 3 of 3
      • Two M1.7x3.0 JIS #000 screws
      • One M1.7x4.5mm JIS #000 screw
      • Use a plastic spudger to pry up on the bottom of the front cover and lift it over the tripod socket.
      • Pull the front cover off the camera body.
      • Electric Shock Warning: With the front cover off, the high voltage capacitor on the DC PCB board is now exposed. It is recommended that you use a capacitor discharge tool to ensure the capacitor is fully discharged before proceeding further.
      Ask FixBot
Attached Documents
Zephosk
6,197 Reputation
39 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 65
All Time: 456
