Introduction
Use this guide to replace a cracked or malfunctioning rear LCD screen on your EOS 6D.
Remove the viewfinder cover by pinching the sides and sliding it upward.
Slide your fingernail or the flat end of the spudger underneath the rubber covering and gently peel it off all sides of the camera.
Open the covers to the HDMI/AV/MIC ports on the side of the camera by gently pulling outward on the bottom of the covers.
Rotate the covers to the side so that you can see the connection ports inside.
Remove the following screws:
Two silver 5mm Phillips #00
One black 6mm Phillips #00
Rotate your camera so the bottom side is facing you.
One 6mm Phillips #00
Two 3mm Phillips #00
Correction:
2x 3mm Phillips #00
1x 6mm Phillips #00 in battery compartment
Figure circle is not correct. Joey Fresco is right.
Carefully use your fingers to tilt the back panel downward to about a 90 degree angle.
Use the flat end of the spudger to gently pry off the ribbon wire from the inside of the camera.
There is a metal piece protruding from the back panel into the main body, down near the battery door. DO NOT simply bend the back panel down 90 degrees! Gently pull the entire back (including the lower right corner near the battery door) straight away from the camera about 1cm, and then lower the back panel 90 degrees.
12 other people completed this guide.
5 Comments
Thank you! Thank you!! I rescued my 6D. All your steps and details were very useful.
Few points to add:
1. I think the black screw (yellow circle) from step 7 is 3 mm.
2. Lift the light brown flap that holds the ribbon cable before removing the LCD panel.
3. When you remove the LCD panel from the metal housing, you will have to pry the two strips of adhesive that is there.
4. Be careful when tightening the screws back.
