Disassembling Canon EOS 60D Removing Rubber grips
  1. Disassembling Canon EOS 60D Removing Rubber grips, Removing Rubber grips: step 1, image 1 of 1
    • Use a thin piece of plastic, spudger, or fingernail (if you have them) to lift up the edge of the grip, and pull up slowly.
    • Repeat for the other two grips
    • The large one on the battery-side is the easiest to start with. This is required to remove the front & back panels
    • The small one on the back is a bit difficult to get started, but not really difficult to remove.
    • The one on the AV panel will be easier if you open up the AV port cover.
    • Remove the adhesive like you would rubber cement, just rub your finger against it, it will come off.
    • Optionally throw the balled up adhesive at people pretending its a booger :)
Eric D
1,284 Reputation
5 Guides authored
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 46
All Time: 11,969
