BlackBerry Curve 8310 Lens Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
73
All Time:
1,469
Comments: 0
Go to guide comments
Completed: 0
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
    1. BlackBerry Curve 8310 Lens Replacement, Battery: step 1, image 1 of 1
      • Press down on the battery release button and slide the back cover up with your thumb.
      Ask FixBot
    2. BlackBerry Curve 8310 Lens Replacement: step 2, image 1 of 1
      • Pry from the top of the battery to pull it out.
      Ask FixBot
    1. BlackBerry Curve 8310 Lens Replacement, Lens: step 3, image 1 of 1
      • Slide the metal sim card cover to the unlock position.
      • Remove the sim card.
      • The arrows on the sim card enclosure indicate the lock and unlock positions.
      Ask FixBot
    2. BlackBerry Curve 8310 Lens Replacement: step 4, image 1 of 1
      • Remove the two T5 Torx screws circled at the top of the phone.
      • The T5 Torx screws may be covered by a white sticker.
      Ask FixBot
    3. BlackBerry Curve 8310 Lens Replacement: step 5, image 1 of 1
      • Remove the red cover at the bottom of the phone.
      • You may have to work a spudger underneath to release the plastic clips.
      Ask FixBot
    4. BlackBerry Curve 8310 Lens Replacement: step 6, image 1 of 3 BlackBerry Curve 8310 Lens Replacement: step 6, image 2 of 3 BlackBerry Curve 8310 Lens Replacement: step 6, image 3 of 3
      • Be careful not to damage the front cover's plastic clips while trying to separate it from the phone.
      • Use a spudger to pry the front cover away from the side panels.
      • Work the spudger around the entire phone until the front cover is free.
      Ask FixBot
Sean Willis
229 Reputation
5 Guides authored
Cal Poly, Team 10-32, Amido Winter 2012 Member of Cal Poly, Team 10-32, Amido Winter 2012
CPSU-AMIDO-W12S10G32
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 73
All Time: 1,469
