Canon EOS 5D Mark II Backup Battery Replacement
  1. Canon EOS 5D Mark II Backup Battery Replacement, Backup Battery: step 1, image 1 of 1
    • Lift the rubber flap covering the input/output jacks.
  2. Canon EOS 5D Mark II Backup Battery Replacement: step 2, image 1 of 1
    • Using a Phillips #0, remove the single 3.4 mm screw.
  3. Canon EOS 5D Mark II Backup Battery Replacement: step 3, image 1 of 1
    • This step will permanently erase all user settings.
    • The memory battery can now be easily slid out of place.
    • If you are following this guide in an effort to perform a hard reset, you should now press the shutter button multiple times in order to drain any left over power, then replace the batteries and power the device back on. You have just performed a hard reset!
Mike Seed
2,956 Reputation
8 Guides authored
USF Tampa, Team 1-6, Hickman Fall 2014 Member of USF Tampa, Team 1-6, Hickman Fall 2014
USFT-HICKMAN-F14S1G6
3 Members
16 Guides authored
Past 24 Hours: 4
Past 7 Days: 30
Past 30 Days: 120
All Time: 25,858
