Canon EOS 40D Flash Hot Shoe Replacement
  1. Canon EOS 40D Flash Hot Shoe Replacement, Battery: step 1, image 1 of 1
    • Locate the battery compartment cover on the bottom of the camera below the shutter button.
  2. Canon EOS 40D Flash Hot Shoe Replacement: step 2, image 1 of 1
    • Find the marked arrow on the battery compartment cover labeled "BATT. OPEN". Slide the lever following the arrow's direction and lift at the same time to release the latch.
  3. Canon EOS 40D Flash Hot Shoe Replacement: step 3, image 1 of 1
    • Release the lever and allow the battery compartment cover to completely open.
    • Remove the battery.
  4. Canon EOS 40D Flash Hot Shoe Replacement, Flash Hot Shoe: step 4, image 1 of 3 Canon EOS 40D Flash Hot Shoe Replacement, Flash Hot Shoe: step 4, image 2 of 3 Canon EOS 40D Flash Hot Shoe Replacement, Flash Hot Shoe: step 4, image 3 of 3
    • Use a metal spudger or opening tool to gently lift the hotshoe plate and slide it off.
  5. Canon EOS 40D Flash Hot Shoe Replacement: step 5, image 1 of 3 Canon EOS 40D Flash Hot Shoe Replacement: step 5, image 2 of 3 Canon EOS 40D Flash Hot Shoe Replacement: step 5, image 3 of 3
    • Remove the four 4.0 mm Phillips #000 screws securing the flash shoe to the camera.
    • Remove the flash shoe.
Sarah de Freitas
277 Reputation
1 Guide authored
USF Tampa, Team 12-3, Blackwell Fall 2015 Member of USF Tampa, Team 12-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G3
4 Members
16 Guides authored
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 50
All Time: 4,403
