Canon EOS 300 Front Panel Replacement
  1. Canon EOS 300 Front Panel Replacement, Batteries: step 1, image 1 of 3 Canon EOS 300 Front Panel Replacement, Batteries: step 1, image 2 of 3 Canon EOS 300 Front Panel Replacement, Batteries: step 1, image 3 of 3
    • Open up the battery door.
  2. Canon EOS 300 Front Panel Replacement: step 2, image 1 of 2 Canon EOS 300 Front Panel Replacement: step 2, image 2 of 2
    • Remove the batteries from the camera by sliding them out into your palm.
  3. Canon EOS 300 Front Panel Replacement, Side Panel with Lever: step 3, image 1 of 2 Canon EOS 300 Front Panel Replacement, Side Panel with Lever: step 3, image 2 of 2
    • Release the side latch to open the back panel.
  4. Canon EOS 300 Front Panel Replacement: step 4, image 1 of 2 Canon EOS 300 Front Panel Replacement: step 4, image 2 of 2
    • Remove the two black 4.5mm screws above and below the latch.
  5. Canon EOS 300 Front Panel Replacement: step 5, image 1 of 2 Canon EOS 300 Front Panel Replacement: step 5, image 2 of 2
    • Using your finger, carefully pry open the side panel from the top of camera.
    • Pull panel downwards to remove.
    • Make sure to keep track of the small black piece of rubber under the latch.
  6. Canon EOS 300 Front Panel Replacement, Front Panel: step 6, image 1 of 2 Canon EOS 300 Front Panel Replacement, Front Panel: step 6, image 2 of 2
    • Remove the two silver 6mm Phillips #1 screws.
  7. Canon EOS 300 Front Panel Replacement: step 7, image 1 of 2 Canon EOS 300 Front Panel Replacement: step 7, image 2 of 2
    • Flip camera over to the bottom.
    • Remove the one 5mm Phillips #1 silver screw.
  8. Canon EOS 300 Front Panel Replacement: step 8, image 1 of 2 Canon EOS 300 Front Panel Replacement: step 8, image 2 of 2
    • Remove the front panel by pulling away from the side with the lever.
Jordan Tang
590 Reputation
5 Guides authored
Cal Poly, Team 6-20, Maness Winter 2014 Member of Cal Poly, Team 6-20, Maness Winter 2014
CPSU-MANESS-W14S6G20
4 Members
32 Guides authored
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 21
All Time: 857
