Canon 7210 Fan Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
21
Past 30 Days:
85
All Time:
817
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 7 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This repair is useful to know how to execute if your projector has overheating issues. Often, a simple fix is just to replace a malfunctioning fan, which is a relatively cheap part. This is much more cost-effective than replacing the entire projector.
Tools
    1. Canon 7210 Fan Replacement, Exterior Shell: step 1, image 1 of 2 Canon 7210 Fan Replacement, Exterior Shell: step 1, image 2 of 2
      • Remove the 4 exterior 9mm Phillips #0 screws. They are located on the sides of the projector.
      Ask FixBot
    2. Canon 7210 Fan Replacement: step 2, image 1 of 3 Canon 7210 Fan Replacement: step 2, image 2 of 3 Canon 7210 Fan Replacement: step 2, image 3 of 3
      • Gently lift up on the shell with both hands, from the back to the front.
      • The shell will still be attached by a small cord in the front, so be careful not to tear it loose.
      Ask FixBot
    1. Canon 7210 Fan Replacement, Fan: step 3, image 1 of 1
      • Remove the two 7mm Phillips #0 screws that attach the fan to the motherboard of the projector.
      Ask FixBot
    2. Canon 7210 Fan Replacement: step 4, image 1 of 1
      • Remove the fan by pulling up gently from the top.
      • Be careful to not pull too hard or quickly, since the fan is still attached to the projector with some other wires.
      Ask FixBot
    3. Canon 7210 Fan Replacement: step 5, image 1 of 1
      • Remove the 7mm Phillips #0 screw that fastens the black ground wire connected to the fan and the projector.
      Ask FixBot
    4. Canon 7210 Fan Replacement: step 6, image 1 of 1
      • Peel the sticker up on the back of the fan to expose the port where the red, white, and black wires are attached.
      • The wires will need to be cut with small wire cutters in order to completely remove the fan.
      Ask FixBot
William Christian
331 Reputation
3 Guides authored
USF Tampa, Team 9-3, Lacy Fall 2016 Member of USF Tampa, Team 9-3, Lacy Fall 2016
USFT-LACY-F16S9G3
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 85
All Time: 817
