Canon 7210 Exterior Shell Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
74
All Time:
616
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 - 4 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide demonstrates how to replace the top exterior shell for the Canon LV-7210. This repair may be necessary if the projector has sustained cosmetic damage. The only tool you will need for this guide is a screwdriver.
Tools
    1. Canon 7210 Exterior Shell Replacement, Exterior Shell: step 1, image 1 of 2 Canon 7210 Exterior Shell Replacement, Exterior Shell: step 1, image 2 of 2
      • Remove the 4 exterior 9mm Phillips #0 screws. They are located on the sides of the projector.
      Ask FixBot
    2. Canon 7210 Exterior Shell Replacement: step 2, image 1 of 3 Canon 7210 Exterior Shell Replacement: step 2, image 2 of 3 Canon 7210 Exterior Shell Replacement: step 2, image 3 of 3
      • Gently lift up on the shell with both hands, from the back to the front.
      • The shell will still be attached by a small cord in the front, so be careful not to tear it loose.
      Ask FixBot
William Christian
331 Reputation
3 Guides authored
USF Tampa, Team 9-3, Lacy Fall 2016 Member of USF Tampa, Team 9-3, Lacy Fall 2016
USFT-LACY-F16S9G3
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 74
All Time: 616
