Up to 20% off select tools
Canary CAN100USBK Front Panel Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
Past 30 Days:
6
All Time:
198
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Very easy
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
This guide will show you how to replace the front panel.
Once the bottom casing has been removed, you can remove the front panel. Removing the front panel gives access to the screws required to remove the motherboard and leverage to pry the top casing off with a spudger.
A spudger is needed for this task.
    1. Canary CAN100USBK Front Panel Replacement, Bottom Casing: step 1, image 1 of 2 Canary CAN100USBK Front Panel Replacement, Bottom Casing: step 1, image 2 of 2
      • Grip the rubber ring with your fingers and pull up.
      • Rotate the Canary as you pull out one tab at a time.
      Ask FixBot
    2. Canary CAN100USBK Front Panel Replacement: step 2, image 1 of 1
      • Use your Phillips #0 screwdriver to remove the four 6mm screws.
      Ask FixBot
    3. Canary CAN100USBK Front Panel Replacement: step 3, image 1 of 3 Canary CAN100USBK Front Panel Replacement: step 3, image 2 of 3 Canary CAN100USBK Front Panel Replacement: step 3, image 3 of 3
      • Use the flat end of the spudger to carefully pry off the bottom casing.
      • Alternate pushing up on the left and right sides until the clips holding the case in are visible.
      Ask FixBot
    4. Canary CAN100USBK Front Panel Replacement: step 4, image 1 of 2 Canary CAN100USBK Front Panel Replacement: step 4, image 2 of 2
      • Do not yank the bottom off or you may damage the ribbon cable or the ZIF connector.
      • Carefully remove the bottom casing by gripping it on both sides and pulling straight up.
      Ask FixBot
    5. Canary CAN100USBK Front Panel Replacement: step 5, image 1 of 2 Canary CAN100USBK Front Panel Replacement: step 5, image 2 of 2
      • Use the pointed end of the spudger to flip up the small retaining flap on the ZIF (zero insertion force) connector.
      • Pull the ribbon cable out towards the device.
      Ask FixBot
    1. Canary CAN100USBK Front Panel Replacement, Front Panel: step 6, image 1 of 2 Canary CAN100USBK Front Panel Replacement, Front Panel: step 6, image 2 of 2
      • There are two empty nooks underneath the bottom of the panel close to each side of the case.
      • Place the pointed edge of the spudger in one of the nooks under the panel and pry upwards.
      Ask FixBot
    2. Canary CAN100USBK Front Panel Replacement: step 7, image 1 of 1
      • Adhesive will have to be reapplied after removing the panel.
      • Pull the panel away from the device.
      Ask FixBot
Author
with
Tommy Nguyen
597 Reputation
5 Guides authored
USF Tampa, Team S1-G2, Nance Spring 2017 Member of USF Tampa, Team S1-G2, Nance Spring 2017
USFT-NANCE-S17S1G2
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 198
