Up to 20% off select tools
Canary CAN100USBK Bottom Casing Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
Past 30 Days:
4
All Time:
192
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
This guide will show you how to remove the bottom casing.
Before you can perform any other replacement guide, you must remove the bottom casing. It gives access to the Ethernet PCB Board, Audio and USB PCB Board and to the nooks where you can pry the front panel off.
As you remove the bottom casing, work slowly to avoid damaging the ribbon cable that is attached to the Audio and USB PCB Board.
A spudger is needed to pry the bottom casing off.
    1. Canary CAN100USBK Bottom Casing Replacement, Bottom Casing: step 1, image 1 of 2 Canary CAN100USBK Bottom Casing Replacement, Bottom Casing: step 1, image 2 of 2
      • Grip the rubber ring with your fingers and pull up.
      • Rotate the Canary as you pull out one tab at a time.
      Ask FixBot
    2. Canary CAN100USBK Bottom Casing Replacement: step 2, image 1 of 1
      • Use your Phillips #0 screwdriver to remove the four 6mm screws.
      Ask FixBot
    3. Canary CAN100USBK Bottom Casing Replacement: step 3, image 1 of 3 Canary CAN100USBK Bottom Casing Replacement: step 3, image 2 of 3 Canary CAN100USBK Bottom Casing Replacement: step 3, image 3 of 3
      • Use the flat end of the spudger to carefully pry off the bottom casing.
      • Alternate pushing up on the left and right sides until the clips holding the case in are visible.
      Ask FixBot
    4. Canary CAN100USBK Bottom Casing Replacement: step 4, image 1 of 2 Canary CAN100USBK Bottom Casing Replacement: step 4, image 2 of 2
      • Do not yank the bottom off or you may damage the ribbon cable or the ZIF connector.
      • Carefully remove the bottom casing by gripping it on both sides and pulling straight up.
      Ask FixBot
    5. Canary CAN100USBK Bottom Casing Replacement: step 5, image 1 of 2 Canary CAN100USBK Bottom Casing Replacement: step 5, image 2 of 2
      • Use the pointed end of the spudger to flip up the small retaining flap on the ZIF (zero insertion force) connector.
      • Pull the ribbon cable out towards the device.
      Ask FixBot
Author
with
Tommy Nguyen
597 Reputation
5 Guides authored
USF Tampa, Team S1-G2, Nance Spring 2017 Member of USF Tampa, Team S1-G2, Nance Spring 2017
USFT-NANCE-S17S1G2
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 192
