Introduction
Removing the shroud of the compressor can be tricky because of wiring that is difficult to see while disassembly. Make sure you carefully read each step of this guide so you do not damage the compressor when removing the shroud. Happy Fixing.
Gently pull the wire attached from the pressure switch to the on/off switch.
It should come off the pressure switch with ease.
Gently pull the wire connected from the on/off switch to the motor of the compressor.
