Cambridge SoundWorks OontZ Angle Plus Battery Replacement
  1. Cambridge SoundWorks OontZ Angle Plus Battery Replacement, Lower Casing: step 1, image 1 of 2 Cambridge SoundWorks OontZ Angle Plus Battery Replacement, Lower Casing: step 1, image 2 of 2
    • Pull back the six screw covers on the bottom of the device.
    • Starting from the screw covers, peel the casing away from the bottom plate.
  2. Cambridge SoundWorks OontZ Angle Plus Battery Replacement, Battery: step 2, image 1 of 1
    • Unscrew the five 11.5mm Phillips screws on the bottom plate.
  3. Cambridge SoundWorks OontZ Angle Plus Battery Replacement: step 3, image 1 of 1
    • Carefully pull apart the bottom plate and the top plate, using the blue plastic opening tool.
  4. Cambridge SoundWorks OontZ Angle Plus Battery Replacement: step 4, image 1 of 1
    • Once the bottom plate and the top plate are separated, slowly pull the back plate away from the top plate.
    • There are wires connected to both plates so do this step with care.
  5. Cambridge SoundWorks OontZ Angle Plus Battery Replacement: step 5, image 1 of 1
    • Unscrew the two 10 mm Phillips screws on the brace holding down the battery.
    • Remove the brace that holds the battery in place.
  6. Cambridge SoundWorks OontZ Angle Plus Battery Replacement: step 6, image 1 of 1
    • Separate the battery from the bottom plate and set the bottom plate aside.
  7. Cambridge SoundWorks OontZ Angle Plus Battery Replacement: step 7, image 1 of 1
    • With some force, push the motherboard straight in toward the center of the device.
  8. Cambridge SoundWorks OontZ Angle Plus Battery Replacement: step 8, image 1 of 1
    • Pull the motherboard straight out of the device.
    • There is some adhesive on the motherboard that holds it in place. This make the motherboard fit in the groove rather tight.
  9. Cambridge SoundWorks OontZ Angle Plus Battery Replacement: step 9, image 1 of 1
    • Desolder the wires that connect the battery to the motherboard, negative (black wire) and positive (red wire).
Artem Nykolenko
203 Reputation
1 Guide authored
USF Tampa, Team 1-1, Nance Spring 2016 Member of USF Tampa, Team 1-1, Nance Spring 2016
USFT-NANCE-S16S1G1
4 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 20
All Time: 6,604
