Repairing Cambridge Audio A3i Amplifier Power Cord and Transformer
  1. Repairing Cambridge Audio A3i Amplifier Power Cord and Transformer, Case: step 1, image 1 of 1
    • Remove 2 screws from each side of the amplifier.
  2. Repairing Cambridge Audio A3i Amplifier Power Cord and Transformer: step 2, image 1 of 1
    • Remove 2 screws on rear of device. Slide top cover up and back from main case.
  3. Repairing Cambridge Audio A3i Amplifier Power Cord and Transformer: step 3, image 1 of 2 Repairing Cambridge Audio A3i Amplifier Power Cord and Transformer: step 3, image 2 of 2
    • Remove 3 screws on bottom of case.
    • Remove 13 screws on rear panel.
    • Do not move the rear panel too far, as the power cord is still connected.
  4. Repairing Cambridge Audio A3i Amplifier Power Cord and Transformer: step 4, image 1 of 1
    • Using a pair of pliers, squeeze the retainer for the power cord as shown and pull it toward the external side the panel.
    • It may require some wiggling, but it should slip out of the hole and then off of the cord.
  5. Repairing Cambridge Audio A3i Amplifier Power Cord and Transformer, Power Cord and Transformer: step 5, image 1 of 1
    • Carefully de-solder ends of power cord from circuit board.
    • Keep track of the colors of the cords. The brown cord leads to the L on the circuit board, and this cord will lead to a fuse in the power plug. The blue cord leads to the N on the board.
    • Finally, pull the power cord through the rear panel to completely remove it.
  6. Repairing Cambridge Audio A3i Amplifier Power Cord and Transformer: step 6, image 1 of 1
    • To remove the transformer the motherboard must be removed. This is to gain access to the solder on the power cords. -See guide for removing motherboard.
    • Remove the 4 nuts holding down the transformer bracket using a 7mm nut driver or socket.
Colby
338 Reputation
3 Guides authored
Cal Poly, Team 28-36, Regan Spring 2010 Member of Cal Poly, Team 28-36, Regan Spring 2010
CPSU-REGAN-S10S28G36
4 Members
3 Guides authored
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 26
All Time: 7,165
