Calculated Industries 8030 Disassembly
    1. Calculated Industries 8030 Disassembly, Removing Screws: step 1, image 1 of 3 Calculated Industries 8030 Disassembly, Removing Screws: step 1, image 2 of 3 Calculated Industries 8030 Disassembly, Removing Screws: step 1, image 3 of 3
      • Remove 3 Back panel screws + 1 battery cover screw.
      • The battery cover screw is larger than the other 3.
      Ask FixBot
    2. Calculated Industries 8030 Disassembly, Releasing side clips: step 2, image 1 of 3 Calculated Industries 8030 Disassembly, Releasing side clips: step 2, image 2 of 3 Calculated Industries 8030 Disassembly, Releasing side clips: step 2, image 3 of 3
      • 3 plastic clips on each side must be released. Using the Jimmy and Prying tool spread the back and front appart slightly. Pry the black plastic out away from the white front cover
      • Tabs are located roughly beside keys "gal" "Yds" Rcl"
      Ask FixBot
    3. Calculated Industries 8030 Disassembly, removing circuit board and cleaning: step 3, image 1 of 2 Calculated Industries 8030 Disassembly, removing circuit board and cleaning: step 3, image 2 of 2
      • Remove 10 screws from circuit board
      • Lift up circuit board careful to support the LCD.
      • Clean the contacts with Isopropyl Alcohol and or repair any broken wires.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Use caution with power wires, ensure they are inside case and not caught in edge.
Bryan Lord
97 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 47
All Time: 201
