Cable set up
  1. Cable set up, Cable set up: step 1, image 1 of 1
    • Check that the red RCA plug is connected to the red RCA jack labeled "R" (this indicates the Right speaker).
    • Check that the white RCA plug is connected to the white RCA jack labeled "L" (this indicates the Left speaker).
    • To connect the ground clip, loosen the ground screw and insert the clip. Once clip is secure tighten the screw.
  2. Cable set up: step 2, image 1 of 1
    • Check the voltage selector switch to make sure its set to the proper voltage depending on your geographic location.
    • Voltage selector should be set to 115 V/60 Hz in the U.S., or 230 V/50 Hz in other countries.
  3. Cable set up: step 3, image 1 of 1
    • Insert power cable into socket.
Finish Line
Nikolai
281 Reputation
5 Guides authored
Cal Poly, Team 17-14, Regan Fall 2011 Member of Cal Poly, Team 17-14, Regan Fall 2011
CPSU-REGAN-F11S17G14
4 Members
11 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 18
All Time: 1,134
