CRKD NEO S CK24NS Trigger Replacement
  1. CRKD NEO S CK24NS Trigger Replacement, Motherboard: step 1, image 1 of 1
    • Turn the CRKD NEO S CK24NS upside down with the front-facing buttons facing downward.
  2. CRKD NEO S CK24NS Trigger Replacement: step 2, image 1 of 3 CRKD NEO S CK24NS Trigger Replacement: step 2, image 2 of 3 CRKD NEO S CK24NS Trigger Replacement: step 2, image 3 of 3
    • Use a 1.5 mm Hex screwdriver to remove the eight 1.5 mm Hex screws from the back of the controller.
    • Carefully lift off the back panel and set it aside.
  3. CRKD NEO S CK24NS Trigger Replacement: step 3, image 1 of 3 CRKD NEO S CK24NS Trigger Replacement: step 3, image 2 of 3 CRKD NEO S CK24NS Trigger Replacement: step 3, image 3 of 3
    • Remove the four 2.5 mm screws holding the motherboard in place using a Phillips #0 screwdriver.
    • Take out the white plastic pieces connected to the motherboard with tweezers.
    • Gently lift the motherboard and set it aside.
    • If the small red plastic piece next to the audio jack falls out, don’t worry. You can pop it back into place during reassembly.
  4. CRKD NEO S CK24NS Trigger Replacement, Trigger: step 4, image 1 of 2 CRKD NEO S CK24NS Trigger Replacement, Trigger: step 4, image 2 of 2
    • Remove the two 2.5 mm Phillips #0 screws and keep them for reassembly.
    • The screws for the left trigger will be on the right.
    • The screws for the right trigger will be on the left.
  5. CRKD NEO S CK24NS Trigger Replacement: step 5, image 1 of 2 CRKD NEO S CK24NS Trigger Replacement: step 5, image 2 of 2
    • Using tweezers, carefully remove the ZL and/or ZR trigger pieces.
    • Insert the new trigger(s) in the same position.
Nick
277 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 170
