Introduction
If the bumpers and/or springs on your CRKD NEO S CK24NS controller are unresponsive or not functioning properly, use this guide to replace them.
Over time, dirt or sediment can build up under the bumpers, causing them to become unresponsive. Use a cotton swab lightly dipped in isopropyl alcohol to clean around the edges and gaps of the bumpers. Let the alcohol evaporate naturally before testing the triggers again. If they still don’t function, follow this guide to disassemble your controller and replace the faulty bumpers and/or springs with new ones.
Ensure the controller is powered off and disconnected from any power source before beginning the repair.
Turn the CRKD NEO S CK24NS upside down with the front-facing buttons facing downward.
Remove the two 2.5 mm Phillips #0 screws and keep them for reassembly.
