Optical drive Replacement
  1. Optical drive Replacement, Optical drive: step 1, image 1 of 1
    • First make sure the laptop is off and closed.
  2. Optical drive Replacement: step 2, image 1 of 1
    • Unlock the battery and push the release lever to remove the battery from the laptop.
  3. Optical drive Replacement: step 3, image 1 of 2 Optical drive Replacement: step 3, image 2 of 2
    • Unscrew the four screws to remove the hard drive cover.
    • Remove these two screws to loosen the hard drive.
    • Gently slide the hard drive out.
    • The hard drive is missing from this device. (Only cover is shown)
  4. Optical drive Replacement: step 4, image 1 of 1
    • Remove all the screws that hold the plastic bottom on. There are some more screws that can't be seen in the photo.
  5. Optical drive Replacement: step 5, image 1 of 1
    • Gently pry up the plastic bottom and if it feels like it is resisting check the surrounding areas for more screws.
  6. Optical drive Replacement: step 6, image 1 of 1
    • Now that the backing plate is off make sure to be careful of the Motherboard and its components from being damaged. From here on out it is recommended that you wear an anti static bracelet or at the very least touching something metal to remove any static electricity that you may have built up.
  7. Optical drive Replacement: step 7, image 1 of 2 Optical drive Replacement: step 7, image 2 of 2
    • There will be a couple more screw holding in the CD tray and once you remove them the CD tray will simply slide out.
2 other people completed this guide.
Eric Martinez
637 Reputation
6 Guides authored
USF Tampa, Team 20-5, Remmell Spring 2017 Member of USF Tampa, Team 20-5, Remmell Spring 2017
USFT-REMMELL-S17S20G5
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 14
All Time: 766
