CHI Spin N Curl Rotating Curler Rotating Barrel Replacement
  1. CHI Spin N Curl Rotating Curler Rotating Barrel Replacement, Power Cord: step 1, image 1 of 1
    • Use a metal spudger to pry off the silver, shiny trim.
  2. CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: step 2, image 1 of 1
    • Remove inner black housing of the CHI Spin N Curl using the metal spudger to pop it out.
  3. CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: step 3, image 1 of 2 CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: step 3, image 2 of 2
    • Use a 2 mm flathead to remove the two screws.
  4. CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: step 4, image 1 of 2 CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: step 4, image 2 of 2
    • Use a metal spudger to pry open the seams of the device.
  5. CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: step 5, image 1 of 3 CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: step 5, image 2 of 3 CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: step 5, image 3 of 3
    • Toward the bottom of the device, grab the swivel power cord.
    • Gently pull the power cord to detach it from the CHI Spin N Curl
    • Replace the faulty cord when the original cord has been removed.
  6. CHI Spin N Curl Rotating Curler Rotating Barrel Replacement, Heating Element: step 6, image 1 of 1
    • After following steps to open the CHI Spin N Curl, locate the heating element.
    • Remove screws on both sides of the heating element.
    • Once screws have been removed, then remove the heating element component.
    • Replace heating element once the original has been removed.
  7. CHI Spin N Curl Rotating Curler Rotating Barrel Replacement, Rotating Barrel: step 7, image 1 of 1
    • Remove all visible screws located near the barrel of the CHI Spin N Curl utilizing a Phillips #00 screwdriver.
    • Screws will be small and black.
  8. CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: step 8, image 1 of 2 CHI Spin N Curl Rotating Curler Rotating Barrel Replacement: step 8, image 2 of 2
    • Remove all screws located near wires using a Phillips #00 screwdriver.
    • Once all surrounding screws have been removed, detach the rotating barrel.
    • Gently remove the rotating barrel and replace once removed.
2 other people completed this guide.
Annalise White
530 Reputation
5 Guides authored
UMass Dartmouth, Team 2-7, Petersen Fall 2022 Member of UMass Dartmouth, Team 2-7, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G7
3 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 23
All Time: 1,075
