CHI Spin N Curl Rotating Curler Directional Buttons Replacement
  1. CHI Spin N Curl Rotating Curler Directional Buttons Replacement, Power Cord: step 1, image 1 of 1
    • Use a metal spudger to pry off the silver, shiny trim.
  2. CHI Spin N Curl Rotating Curler Directional Buttons Replacement: step 2, image 1 of 1
    • Remove inner black housing of the CHI Spin N Curl using the metal spudger to pop it out.
  3. CHI Spin N Curl Rotating Curler Directional Buttons Replacement: step 3, image 1 of 2 CHI Spin N Curl Rotating Curler Directional Buttons Replacement: step 3, image 2 of 2
    • Use a 2 mm flathead to remove the two screws.
  4. CHI Spin N Curl Rotating Curler Directional Buttons Replacement: step 4, image 1 of 2 CHI Spin N Curl Rotating Curler Directional Buttons Replacement: step 4, image 2 of 2
    • Use a metal spudger to pry open the seams of the device.
  5. CHI Spin N Curl Rotating Curler Directional Buttons Replacement: step 5, image 1 of 3 CHI Spin N Curl Rotating Curler Directional Buttons Replacement: step 5, image 2 of 3 CHI Spin N Curl Rotating Curler Directional Buttons Replacement: step 5, image 3 of 3
    • Toward the bottom of the device, grab the swivel power cord.
    • Gently pull the power cord to detach it from the CHI Spin N Curl
    • Replace the faulty cord when the original cord has been removed.
  6. CHI Spin N Curl Rotating Curler Directional Buttons Replacement, Motherboard: step 6, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the screws holding the barrel in.
  7. CHI Spin N Curl Rotating Curler Directional Buttons Replacement: step 7, image 1 of 1
    • Remove the screws using Phillips #00 screwdriver and take off the components.
    • Once all screws are removed, take out the barrel accessing the motherboard underneath.
  8. CHI Spin N Curl Rotating Curler Directional Buttons Replacement: step 8, image 1 of 1
    • Using metal spudger, lift and remove the motherboard and disconnect the top components.
  9. CHI Spin N Curl Rotating Curler Directional Buttons Replacement, Directional Buttons: step 9, image 1 of 1
    • After the motherboard is removed, use the metal spudger to push and remove the directional buttons, and wipe underneath with a slightly damp alcohol cotton pad.
Annalise White
530 Reputation
5 Guides authored
UMass Dartmouth, Team 2-7, Petersen Fall 2022 Member of UMass Dartmouth, Team 2-7, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G7
3 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 32
All Time: 849
