CAT S62 Top Camera Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
10
Past 30 Days:
63
All Time:
251
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 50 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This is a comprehensive guide to replacing the top camera of the CAT S62 phone.
Symptoms of a malfunctioning top camera include:
  • Blurry photos
  • Black screen when you open the camera app
  • The camera app freezes and crashes
  • Photos are pixelated
Tools
    1. CAT S62 Top Camera Replacement, Battery: step 1, image 1 of 2 CAT S62 Top Camera Replacement, Battery: step 1, image 2 of 2
      • Allow your phone's battery to drain below 25% (a charged lithium-ion battery can be a safety hazard). Turn the device off before working on it.
      • Use the plastic spudger to gently pry off the rubber back panel. If needed, use the plastic iFixit opening picks to help keep the plate separated. (Heating the back of the phone using a blow dryer may help loosen adhesive.)
      • Gently pull the back panel away to avoid damaging the connecting wire for the fingerprint sensor.
      Ask FixBot
    2. CAT S62 Top Camera Replacement: step 2, image 1 of 2 CAT S62 Top Camera Replacement: step 2, image 2 of 2
      • Gently remove the wire connecting the back cover to the rest of the phone using your fingers or tweezers.
      • Do not pull on the wire, as it may damage the cable.
      Ask FixBot
    3. CAT S62 Top Camera Replacement: step 3, image 1 of 3 CAT S62 Top Camera Replacement: step 3, image 2 of 3 CAT S62 Top Camera Replacement: step 3, image 3 of 3
      • Remove the eleven 5mm screws with a JIS #00 screwdriver.
      • Remove the six 3mm screws (three screws on each side) with a Hex 1.3 mm screwdriver.
      Ask FixBot
    4. CAT S62 Top Camera Replacement: step 4, image 1 of 1
      • The battery cover is connected to the camera cover, so both covers must be removed to access the battery.
      • Pry off the camera cover using the iFixit opening picks.
      • Remove both plates.
      • The two plates are connected by a small wire. Handle with care and do not separate them from each other.
      Ask FixBot
    5. CAT S62 Top Camera Replacement: step 5, image 1 of 2 CAT S62 Top Camera Replacement: step 5, image 2 of 2
      • Disconnect the wire attached to the battery using the tweezers or your fingers.
      Ask FixBot
    6. CAT S62 Top Camera Replacement: step 6, image 1 of 1
      • Use a blow dryer or other heating device for a few minutes to loosen the adhesive beneath the battery.
      • Be extremely careful handling heated metal, as it will be hot to the touch.
      • Pry the battery away using the plastic spudger and iFixit opening picks.
      Ask FixBot
    1. CAT S62 Top Camera Replacement, Motherboard: step 7, image 1 of 2 CAT S62 Top Camera Replacement, Motherboard: step 7, image 2 of 2
      • Using the precision tweezers, gently unclip the white cable from the motherboard.
      Ask FixBot
    2. CAT S62 Top Camera Replacement: step 8, image 1 of 2 CAT S62 Top Camera Replacement: step 8, image 2 of 2
      • Using precision tweezers, unclip the two connectors from the motherboard.
      Ask FixBot
    3. CAT S62 Top Camera Replacement: step 9, image 1 of 1
      • Remove one 3 mm screw from the motherboard using a JIS #00 screwdriver.
      Ask FixBot
    4. CAT S62 Top Camera Replacement: step 10, image 1 of 2 CAT S62 Top Camera Replacement: step 10, image 2 of 2
      • Using the spudger and precision tweezers, gently remove the motherboard.
      Ask FixBot
    1. CAT S62 Top Camera Replacement, Top Camera: step 11, image 1 of 1
      • Using the precision tweezers, gently unclip the black connector from the motherboard.
      Ask FixBot
    2. CAT S62 Top Camera Replacement: step 12, image 1 of 1
      • Remove the camera with precision tweezers.
      Ask FixBot
Cassandra Schrammen
725 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 63
All Time: 251
