CAT S62 Microphone Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
12
Past 30 Days:
92
All Time:
472
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 55 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This is a comprehensive guide to replacing the microphone of the CAT S62 phone.
Symptoms of a malfunctioning microphone are:
  • The other party cannot hear you during phone calls.
  • No sound or very quiet sound is recorded when using a voice recorder app or recording video.
  • Your voice sounds choppy, distant, or "underwater" to the person on the other end of the line.
Tools
    1. CAT S62 Microphone Replacement, Battery: step 1, image 1 of 2 CAT S62 Microphone Replacement, Battery: step 1, image 2 of 2
      • Allow your phone's battery to drain below 25% (a charged lithium-ion battery can be a safety hazard). Turn the device off before working on it.
      • Use the plastic spudger to gently pry off the rubber back panel. If needed, use the plastic iFixit opening picks to help keep the plate separated. (Heating the back of the phone using a blow dryer may help loosen adhesive.)
      • Gently pull the back panel away to avoid damaging the connecting wire for the fingerprint sensor.
      Ask FixBot
    2. CAT S62 Microphone Replacement: step 2, image 1 of 2 CAT S62 Microphone Replacement: step 2, image 2 of 2
      • Gently remove the wire connecting the back cover to the rest of the phone using your fingers or tweezers.
      • Do not pull on the wire, as it may damage the cable.
      Ask FixBot
    3. CAT S62 Microphone Replacement: step 3, image 1 of 3 CAT S62 Microphone Replacement: step 3, image 2 of 3 CAT S62 Microphone Replacement: step 3, image 3 of 3
      • Remove the eleven 5mm screws with a JIS #00 screwdriver.
      • Remove the six 3mm screws (three screws on each side) with a Hex 1.3 mm screwdriver.
      Ask FixBot
    4. CAT S62 Microphone Replacement: step 4, image 1 of 1
      • The battery cover is connected to the camera cover, so both covers must be removed to access the battery.
      • Pry off the camera cover using the iFixit opening picks.
      • Remove both plates.
      • The two plates are connected by a small wire. Handle with care and do not separate them from each other.
      Ask FixBot
    5. CAT S62 Microphone Replacement: step 5, image 1 of 2 CAT S62 Microphone Replacement: step 5, image 2 of 2
      • Disconnect the wire attached to the battery using the tweezers or your fingers.
      Ask FixBot
    6. CAT S62 Microphone Replacement: step 6, image 1 of 1
      • Use a blow dryer or other heating device for a few minutes to loosen the adhesive beneath the battery.
      • Be extremely careful handling heated metal, as it will be hot to the touch.
      • Pry the battery away using the plastic spudger and iFixit opening picks.
      Ask FixBot
    1. CAT S62 Microphone Replacement, Bottom Speaker: step 7, image 1 of 1
      • Remove the three 5mm screws using a JIS #00 screwdriver.
      Ask FixBot
    2. CAT S62 Microphone Replacement: step 8, image 1 of 2 CAT S62 Microphone Replacement: step 8, image 2 of 2
      • Gently pull the speaker upwards to remove it.
      Ask FixBot
    1. CAT S62 Microphone Replacement, Microphone: step 9, image 1 of 2 CAT S62 Microphone Replacement, Microphone: step 9, image 2 of 2
      • Flip the speaker over and locate the silver circular microphone.
      • Insert the pencil end of the spudger underneath the microphone and pry it up.
      • Carefully pull the bronze colored microphone cable upwards to remove it.
      • The bronze cable is fragile and prone to tearing easily. Remove with care.
      Ask FixBot
    2. CAT S62 Microphone Replacement: step 10, image 1 of 1
      • Use tweezers or your fingernail to wedge underneath the silver bit and pull with some force, as it is glued in.
      Ask FixBot
Cassandra Schrammen
725 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 92
All Time: 472
