Buttons Removal (Action and D-pad)
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Buttons Removal (Action and D-pad), Prepare your Game Boy for disassembly: step 1, image 1 of 3 Buttons Removal (Action and D-pad), Prepare your Game Boy for disassembly: step 1, image 2 of 3 Buttons Removal (Action and D-pad), Prepare your Game Boy for disassembly: step 1, image 3 of 3
      • Slide the power switch to the OFF position and unplug any cables.
      • If you have a game cartridge in, remove it.
      Ask FixBot
    2. Buttons Removal (Action and D-pad), Remove the battery cover: step 2, image 1 of 2 Buttons Removal (Action and D-pad), Remove the battery cover: step 2, image 2 of 2
      • Use a JIS 00 screwdriver to loosen the captive screw securing the battery cover.
      • You can try to use a non-iFixit Phillips driver in a pinch, but you risk damaging or stripping the screw. Push down firmly on the driver and twist slowly.
      Ask FixBot
    3. Buttons Removal (Action and D-pad): step 3, image 1 of 3 Buttons Removal (Action and D-pad): step 3, image 2 of 3 Buttons Removal (Action and D-pad): step 3, image 3 of 3
      • Lift the edge of the cover near the screw and remove the cover.
      • During reassembly, hook the tabs on the bottom edge of the cover into their slots and lay the cover into place.
      Ask FixBot
    4. Buttons Removal (Action and D-pad), Remove the battery: step 4, image 1 of 3 Buttons Removal (Action and D-pad), Remove the battery: step 4, image 2 of 3 Buttons Removal (Action and D-pad), Remove the battery: step 4, image 3 of 3
      • Use your finger to lift the battery by the tab on its left edge, then remove it.
      • During reassembly:
      • Never reuse a deformed or damaged battery—it's a fire hazard. Replace it with a new battery.
      • Your replacement battery may come with a plastic enclosure that slides over the battery.
      • Insert the edge of the battery with contacts at a slight downward angle—aligning the contacts with their prongs in the recess—and press the battery into place.
      Ask FixBot
    1. Buttons Removal (Action and D-pad), Remove the bottom shell: step 5, image 1 of 2 Buttons Removal (Action and D-pad), Remove the bottom shell: step 5, image 2 of 2
      • Use a tri‑point Y0 screwdriver to remove the six screws securing the bottom shell:
      • Four 6.3 mm‑long recessed screws
      • Two 4.6 mm‑long screws
      Ask FixBot
    2. Buttons Removal (Action and D-pad): step 6, image 1 of 2 Buttons Removal (Action and D-pad): step 6, image 2 of 2
      • Lift the bottom shell straight up and remove it.
      Ask FixBot
    1. Buttons Removal (Action and D-pad), Remove the power switch cover: step 7, image 1 of 2 Buttons Removal (Action and D-pad), Remove the power switch cover: step 7, image 2 of 2
      • Use your fingers to lift and remove the power switch cover.
      • Use your fingers to put the power switch cover (notched side up) into place so the cutout goes around the actual switch.
      • Gently slide the cover back and forth to make sure it's positioned properly and moving the switch.
      • If the switch isn't properly in its cutout, you won't be able to power on your Game Boy.
      Ask FixBot
    2. Buttons Removal (Action and D-pad), Remove the motherboard screws: step 8, image 1 of 2 Buttons Removal (Action and D-pad), Remove the motherboard screws: step 8, image 2 of 2
      • Use a JIS 00 screwdriver to remove the three 4.1 mm‑long screws securing the motherboard.
      Ask FixBot
    3. Buttons Removal (Action and D-pad), Prop up the motherboard: step 9, image 1 of 3 Buttons Removal (Action and D-pad), Prop up the motherboard: step 9, image 2 of 3 Buttons Removal (Action and D-pad), Prop up the motherboard: step 9, image 3 of 3
      • Place a sturdy object such as a stack of books or tool case along the edge of your Game Boy with the hinges.
      • Use your fingers to gently flip the motherboard over the hinges and prop it up.
      Ask FixBot
    1. Buttons Removal (Action and D-pad), Remove the silicone pads: step 10, image 1 of 3 Buttons Removal (Action and D-pad), Remove the silicone pads: step 10, image 2 of 3 Buttons Removal (Action and D-pad), Remove the silicone pads: step 10, image 3 of 3
      • Use tweezers or your fingers to remove the four silicone pads covering the buttons (A and B, D‑pad, brightness, and Start/Select).
      • If any of the pads are missing, they may be stuck to their corresponding spot on the motherboard.
      Ask FixBot
    2. Buttons Removal (Action and D-pad), Remove the buttons: step 11, image 1 of 3 Buttons Removal (Action and D-pad), Remove the buttons: step 11, image 2 of 3 Buttons Removal (Action and D-pad), Remove the buttons: step 11, image 3 of 3
      • Use tweezers or your fingers to remove the buttons (A and B, D‑pad, brightness, and Start/Select).
      • When re‑inserting the action buttons, note that each one is keyed specifically for its recess and proper orientation.
      Ask FixBot
Finish Line
Spencer Day
206,063 Reputation
1,267 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 12
All Time: 137
