Shop the Holiday Gift Guide
Button Board Removal
View statistics:
Past 24 Hours:
3
Past 7 Days:
8
Past 30 Days:
24
All Time:
193
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
How to remove the button board in your Analogue Pocket.
Tools
    1. Button Board Removal, Prepare your device for disassembly: step 1, image 1 of 3 Button Board Removal, Prepare your device for disassembly: step 1, image 2 of 3 Button Board Removal, Prepare your device for disassembly: step 1, image 3 of 3
      • Unplug all cables and fully power off your device.
      • Working on your device requires laying it screen-side down. To prevent damage, lay it on a soft surface such as a towel.
      Ask FixBot
    1. Button Board Removal, Unfasten the battery shell: step 2, image 1 of 2 Button Board Removal, Unfasten the battery shell: step 2, image 2 of 2
      • Use a T6 Torx screwdriver to remove the four 13.4 mm‑long screws securing the battery shell.
      Ask FixBot
    2. Button Board Removal, Remove the battery shell: step 3, image 1 of 3 Button Board Removal, Remove the battery shell: step 3, image 2 of 3 Button Board Removal, Remove the battery shell: step 3, image 3 of 3
      Ask FixBot
    1. Button Board Removal, Disconnect the battery: step 4, image 1 of 2 Button Board Removal, Disconnect the battery: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Use blunt nose tweezers to pull the battery connector out of its socket on the bottom right corner of your device.
      • If you're having trouble, try rocking the connector side-to-side to help loosen it.
      • During reassembly, use the flat end of a spudger to push down on the edges of the connector until it's secure in the socket.
      Ask FixBot
    2. Button Board Removal, Remove the battery: step 5, image 1 of 3 Button Board Removal, Remove the battery: step 5, image 2 of 3 Button Board Removal, Remove the battery: step 5, image 3 of 3
      • Lift one of the battery's short edges until the clips release.
      • Remove the battery.
      • During reassembly, push the battery into its recess until the clips engage.
      Ask FixBot
    1. Button Board Removal, Unclip the button board: step 6, image 1 of 3 Button Board Removal, Unclip the button board: step 6, image 2 of 3 Button Board Removal, Unclip the button board: step 6, image 3 of 3
      • A plastic clip secures the center of the button board.
      • Use the point of a spudger to push the clip out and release the board.
      • Don't try to remove the board—a delicate ribbon cable secures it to the device.
      Ask FixBot
    2. Button Board Removal, Reposition the button board: step 7, image 1 of 3 Button Board Removal, Reposition the button board: step 7, image 2 of 3 Button Board Removal, Reposition the button board: step 7, image 3 of 3
      • Swing the bottom edge of the button board up and over the cartridge reader.
      • Set the board on top of the cartridge reader so the cable's connector is facing the bottom of the device.
      • During reassembly:
      • Put the top edges of the board under their tabs on the rear shell.
      • Lay the board onto the rear shell so the alignment posts go into their circular cutouts on the board.
      • Press the board down until the plastic clip engages.
      Ask FixBot
    3. Button Board Removal, Disconnect the button board: step 8, image 1 of 3 Button Board Removal, Disconnect the button board: step 8, image 2 of 3 Button Board Removal, Disconnect the button board: step 8, image 3 of 3
      • Use the tip of a spudger or a clean fingernail to flip up the hinged locking flap on the board cable ZIF connector located on the board itself.
      • Use blunt nose tweezers to pull the cable straight out of its socket.
      Ask FixBot
    4. Button Board Removal, Remove the board: step 9, image 1 of 2 Button Board Removal, Remove the board: step 9, image 2 of 2
      • Remove the board.
      Ask FixBot
Author
with
Spencer Day
210,392 Reputation
1,265 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,954 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 24
All Time: 193
