Replacing Bush Pump Traveling Valve
  1. Replacing Bush Pump Traveling Valve, Head and Handle: step 1, image 1 of 2 Replacing Bush Pump Traveling Valve, Head and Handle: step 1, image 2 of 2
    • Test pump performance by pumping 40 strokes.
    • An effective pump should return at least 10 liters.
  2. Replacing Bush Pump Traveling Valve: step 2, image 1 of 2 Replacing Bush Pump Traveling Valve: step 2, image 2 of 2
    • Remove the two pins connecting the handle to the slider.
  3. Replacing Bush Pump Traveling Valve: step 3, image 1 of 2 Replacing Bush Pump Traveling Valve: step 3, image 2 of 2
    • Pull the two lever arms away from the slider.
  4. Replacing Bush Pump Traveling Valve: step 4, image 1 of 2 Replacing Bush Pump Traveling Valve: step 4, image 2 of 2
    • Lift the two pins attaching the pump frame to the head and handle up, off of the pump frame.
  5. Replacing Bush Pump Traveling Valve: step 5, image 1 of 3 Replacing Bush Pump Traveling Valve: step 5, image 2 of 3 Replacing Bush Pump Traveling Valve: step 5, image 3 of 3
    • Throughout this step, make sure you support the handle and head with at least three hands.
    • Slide the bearing rod out of the head.
    • Inspect the bearing rod and head for any wear or tear.
  6. Replacing Bush Pump Traveling Valve: step 6, image 1 of 1
    • Remove the head and handle, and place them on a clean surface to prevent contamination.
  7. Replacing Bush Pump Traveling Valve, Riser Main Slider: step 7, image 1 of 2 Replacing Bush Pump Traveling Valve, Riser Main Slider: step 7, image 2 of 2
    • Firmly lift the riser main slider with two hands.
    • Use caution not to drop the riser main, as this can damage the pump cylinder.
  8. Replacing Bush Pump Traveling Valve: step 8, image 1 of 3 Replacing Bush Pump Traveling Valve: step 8, image 2 of 3 Replacing Bush Pump Traveling Valve: step 8, image 3 of 3
    • Use a pipe wrench to fully loosen the above grade riser pipe.
  9. Replacing Bush Pump Traveling Valve: step 9, image 1 of 3 Replacing Bush Pump Traveling Valve: step 9, image 2 of 3 Replacing Bush Pump Traveling Valve: step 9, image 3 of 3
    • Lift the slider and riser main pipe.
    • Place a pump rod clamp around the rod, and tighten it securely against the pump rod.
    • Carefully lower the riser main and slider to allow it to rest on the rod clamp.
  10. Replacing Bush Pump Traveling Valve: step 10, image 1 of 3 Replacing Bush Pump Traveling Valve: step 10, image 2 of 3 Replacing Bush Pump Traveling Valve: step 10, image 3 of 3
    • Loosen and remove both the pump rod jam nut and pump rod nut on the top of the slider.
  11. Replacing Bush Pump Traveling Valve: step 11, image 1 of 2 Replacing Bush Pump Traveling Valve: step 11, image 2 of 2
    • Remove the riser main slider, and inspect it for wear and tear.
    • Set the slider in a sanitary place to prevent contamination.
  12. Replacing Bush Pump Traveling Valve, Above Grade Riser Pipe: step 12, image 1 of 3 Replacing Bush Pump Traveling Valve, Above Grade Riser Pipe: step 12, image 2 of 3 Replacing Bush Pump Traveling Valve, Above Grade Riser Pipe: step 12, image 3 of 3
    • Remove the above grade riser pipe.
    • Firmly screw a T-handle onto the pump rod.
    • If you are replacing the above ground riser main, leave the T-handle attached until you are ready to install the replacement part.
  13. Replacing Bush Pump Traveling Valve, Spout: step 13, image 1 of 3 Replacing Bush Pump Traveling Valve, Spout: step 13, image 2 of 3 Replacing Bush Pump Traveling Valve, Spout: step 13, image 3 of 3
    • Use a pipe wrench to loosen and remove the pump spout.
    • Inspect the spout for obstructions or potential contaminants.
    • Place the spout on a clean surface to prevent any contamination.
  14. Replacing Bush Pump Traveling Valve, Riser Main: step 14, image 1 of 3 Replacing Bush Pump Traveling Valve, Riser Main: step 14, image 2 of 3 Replacing Bush Pump Traveling Valve, Riser Main: step 14, image 3 of 3
    • Place one wrench on the top of one of the pump riser plate bolts.
    • Place another wrench around the bottom of the bolt.
    • Pull the wrenches apart to loosen the bolt.
    • Repeat this procedure for the remaining three bolts.
  15. Replacing Bush Pump Traveling Valve: step 15, image 1 of 2 Replacing Bush Pump Traveling Valve: step 15, image 2 of 2
    • Remove the four nuts and bolts securing the pump riser plate, and store them in a sanitary container such as a bucket.
  16. Replacing Bush Pump Traveling Valve: step 16, image 1 of 2 Replacing Bush Pump Traveling Valve: step 16, image 2 of 2
    • Rotate the pump plate 45 degrees. This will allow for a better grasp when lifting the plate.
  17. Replacing Bush Pump Traveling Valve: step 17, image 1 of 3 Replacing Bush Pump Traveling Valve: step 17, image 2 of 3 Replacing Bush Pump Traveling Valve: step 17, image 3 of 3
    • Securely lift the T-handle several inches.
    • While 2 people support the T-handle, remove the pump rod clamp.
    • Lower the T-handle gently until the pump rod is supporting itself.
  18. Replacing Bush Pump Traveling Valve: step 18, image 1 of 3 Replacing Bush Pump Traveling Valve: step 18, image 2 of 3 Replacing Bush Pump Traveling Valve: step 18, image 3 of 3
    • This particular pump is using a tripod with a block and tackle to lift the riser main. C-wrenches may also be used to lift the riser main.
    • Securely clamp and tighten the pipe elevator to the riser main below the spout exit.
  19. Replacing Bush Pump Traveling Valve: step 19, image 1 of 2 Replacing Bush Pump Traveling Valve: step 19, image 2 of 2
    • Being careful not to let the rope slip, use the block and tackle to lift the riser main until the pipe elevator reaches the block and tackle.
  20. Replacing Bush Pump Traveling Valve: step 20, image 1 of 3 Replacing Bush Pump Traveling Valve: step 20, image 2 of 3 Replacing Bush Pump Traveling Valve: step 20, image 3 of 3
    • Once the riser main has reached the block and tackle, tighten the base clamp against the riser main.
  21. Replacing Bush Pump Traveling Valve: step 21, image 1 of 3 Replacing Bush Pump Traveling Valve: step 21, image 2 of 3 Replacing Bush Pump Traveling Valve: step 21, image 3 of 3
    • Secure the base clamp to the frame base using a bolt.
    • One bolt is typically sufficient to keep the base clamp in place, but you can add another bolt if you wish to further secure it.
  22. Replacing Bush Pump Traveling Valve: step 22, image 1 of 3 Replacing Bush Pump Traveling Valve: step 22, image 2 of 3 Replacing Bush Pump Traveling Valve: step 22, image 3 of 3
    • While supporting the top portion of the pipe, carefully move the elevator clamp off of the pipe.
    • Lower the elevator clamp while providing tension towards the ground to prevent the ropes from tangling in the block and tackle.
  23. Replacing Bush Pump Traveling Valve: step 23, image 1 of 3 Replacing Bush Pump Traveling Valve: step 23, image 2 of 3 Replacing Bush Pump Traveling Valve: step 23, image 3 of 3
    • Attach and tighten the elevator clamp to the riser main as close to the bottom as possible.
  24. Replacing Bush Pump Traveling Valve: step 24, image 1 of 2 Replacing Bush Pump Traveling Valve: step 24, image 2 of 2
    • Once the elevator clamp is tight, provide tension on the rope.
    • While keeping tension on the rope to support the riser, loosen the base clamp.
  25. Replacing Bush Pump Traveling Valve: step 25, image 1 of 3 Replacing Bush Pump Traveling Valve: step 25, image 2 of 3 Replacing Bush Pump Traveling Valve: step 25, image 3 of 3
    • Use the rope to pull the riser main up as far as comfortable.
    • Be sure to keep the rope within the confines of the tripod to prevent the tripod from pulling over.
    • Watch the top of the tripod to align the riser main in the support slot.
  26. Replacing Bush Pump Traveling Valve: step 26, image 1 of 3 Replacing Bush Pump Traveling Valve: step 26, image 2 of 3 Replacing Bush Pump Traveling Valve: step 26, image 3 of 3
    • Remove the clamp from the riser main, and repeat steps 23-25 until first joint is exposed.
  27. Replacing Bush Pump Traveling Valve: step 27, image 1 of 3 Replacing Bush Pump Traveling Valve: step 27, image 2 of 3 Replacing Bush Pump Traveling Valve: step 27, image 3 of 3
    • Once the first joint is exposed, tighten the base clamp below the joint.
  28. Replacing Bush Pump Traveling Valve: step 28, image 1 of 1
    • Remove the elevator clamp from the riser main, and secure it to the tripod to keep it out of the way.
  29. Replacing Bush Pump Traveling Valve: step 29, image 1 of 2 Replacing Bush Pump Traveling Valve: step 29, image 2 of 2
    • Keep the pipe wrench a few inches above the joint in this step.
    • Using a pipe wrench, unscrew the first section of the riser main from the connection.
  30. Replacing Bush Pump Traveling Valve: step 30, image 1 of 3 Replacing Bush Pump Traveling Valve: step 30, image 2 of 3 Replacing Bush Pump Traveling Valve: step 30, image 3 of 3
    • Secure a splash guard over the joint to prevent water from spraying out of the connection when separated.
    • Using the pipe wrench, loosen the riser main until water begins to spray into the splash guard.
    • Do not loosen it any further until the water has stopped spraying.
  31. Replacing Bush Pump Traveling Valve: step 31, image 1 of 3 Replacing Bush Pump Traveling Valve: step 31, image 2 of 3 Replacing Bush Pump Traveling Valve: step 31, image 3 of 3
    • Remove the splash guard, and finish loosening the riser main.
    • Remove the first section of the riser main by lifting it straight up, while supporting the top of the section and keeping the pipe within the support slot on the top of the tripod.
  32. Replacing Bush Pump Traveling Valve: step 32, image 1 of 3 Replacing Bush Pump Traveling Valve: step 32, image 2 of 3 Replacing Bush Pump Traveling Valve: step 32, image 3 of 3
    • Attach and tighten the rod clamp a few inches below the first pump rod connection.
  33. Replacing Bush Pump Traveling Valve: step 33, image 1 of 3 Replacing Bush Pump Traveling Valve: step 33, image 2 of 3 Replacing Bush Pump Traveling Valve: step 33, image 3 of 3
    • Using two crescent wrenches, unscrew the pump rod from the remaining portion.
    • When the joint is separated, carefully lower the riser main to the ground.
  34. Replacing Bush Pump Traveling Valve: step 34, image 1 of 3 Replacing Bush Pump Traveling Valve: step 34, image 2 of 3 Replacing Bush Pump Traveling Valve: step 34, image 3 of 3
    • Carefully lower the riser main, horizontally, and place it in a sanitary place, preferably resting above the ground, to prevent contamination.
  35. Replacing Bush Pump Traveling Valve: step 35, image 1 of 3 Replacing Bush Pump Traveling Valve: step 35, image 2 of 3 Replacing Bush Pump Traveling Valve: step 35, image 3 of 3
    • Remove the T-handle from the separated pump rod.
    • Attach the T-handle to the remaining pump rod.
    • Remove the rod clamp and repeat steps 29-35 until the riser main is completely removed, or until the broken section is reached.
  36. Replacing Bush Pump Traveling Valve, Cylinder: step 36, image 1 of 1
    • Make sure to keep the cylinder off the ground to prevent contamination.
  37. Replacing Bush Pump Traveling Valve: step 37, image 1 of 3 Replacing Bush Pump Traveling Valve: step 37, image 2 of 3 Replacing Bush Pump Traveling Valve: step 37, image 3 of 3
    • Using two pipe wrenches, unscrew the cylinder from the riser main.
  38. Replacing Bush Pump Traveling Valve: step 38, image 1 of 2 Replacing Bush Pump Traveling Valve: step 38, image 2 of 2
    • Slowly pull the cylinder off of the pump rod, exposing the traveling valve and foot valve.
  39. Replacing Bush Pump Traveling Valve, Traveling Valve: step 39, image 1 of 3 Replacing Bush Pump Traveling Valve, Traveling Valve: step 39, image 2 of 3 Replacing Bush Pump Traveling Valve, Traveling Valve: step 39, image 3 of 3
    • Insert a wrench into the slots located at the bottom of the traveling valve.
    • Using another wrench for leverage, unscrew the valve off the pump rod.
  40. Replacing Bush Pump Traveling Valve: step 40, image 1 of 2 Replacing Bush Pump Traveling Valve: step 40, image 2 of 2
    • Unscrew the valve from the pump rod.
  41. Replacing Bush Pump Traveling Valve: step 41, image 1 of 3 Replacing Bush Pump Traveling Valve: step 41, image 2 of 3 Replacing Bush Pump Traveling Valve: step 41, image 3 of 3
    • Be careful to keep the valve parts off the ground.
    • Check the valve components for signs of wear and tear.
  42. Replacing Bush Pump Traveling Valve: step 42, image 1 of 2 Replacing Bush Pump Traveling Valve: step 42, image 2 of 2
    • Remove the poppet from the valve to check for signs of wear.
    • Be sure to take note of the order and direction of the components for reassembly. This is essential, as the pump will not work if the valve is not reinstalled correctly.
Jake Devincenzi
117,422 Reputation
57 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 255
