Replacing Bush Pump Riser Main Slider
  1. Replacing Bush Pump Riser Main Slider, Head and Handle: step 1, image 1 of 2 Replacing Bush Pump Riser Main Slider, Head and Handle: step 1, image 2 of 2
    • Test pump performance by pumping 40 strokes.
    • An effective pump should return at least 10 liters.
  2. Replacing Bush Pump Riser Main Slider: step 2, image 1 of 2 Replacing Bush Pump Riser Main Slider: step 2, image 2 of 2
    • Remove the two pins connecting the handle to the slider.
  3. Replacing Bush Pump Riser Main Slider: step 3, image 1 of 2 Replacing Bush Pump Riser Main Slider: step 3, image 2 of 2
    • Pull the two lever arms away from the slider.
  4. Replacing Bush Pump Riser Main Slider: step 4, image 1 of 2 Replacing Bush Pump Riser Main Slider: step 4, image 2 of 2
    • Lift the two pins attaching the pump frame to the head and handle up, off of the pump frame.
  5. Replacing Bush Pump Riser Main Slider: step 5, image 1 of 3 Replacing Bush Pump Riser Main Slider: step 5, image 2 of 3 Replacing Bush Pump Riser Main Slider: step 5, image 3 of 3
    • Throughout this step, make sure you support the handle and head with at least three hands.
    • Slide the bearing rod out of the head.
    • Inspect the bearing rod and head for any wear or tear.
  6. Replacing Bush Pump Riser Main Slider: step 6, image 1 of 1
    • Remove the head and handle, and place them on a clean surface to prevent contamination.
  7. Replacing Bush Pump Riser Main Slider, Riser Main Slider: step 7, image 1 of 2 Replacing Bush Pump Riser Main Slider, Riser Main Slider: step 7, image 2 of 2
    • Firmly lift the riser main slider with two hands.
    • Use caution not to drop the riser main, as this can damage the pump cylinder.
  8. Replacing Bush Pump Riser Main Slider: step 8, image 1 of 3 Replacing Bush Pump Riser Main Slider: step 8, image 2 of 3 Replacing Bush Pump Riser Main Slider: step 8, image 3 of 3
    • Use a pipe wrench to fully loosen the above grade riser pipe.
  9. Replacing Bush Pump Riser Main Slider: step 9, image 1 of 3 Replacing Bush Pump Riser Main Slider: step 9, image 2 of 3 Replacing Bush Pump Riser Main Slider: step 9, image 3 of 3
    • Lift the slider and riser main pipe.
    • Place a pump rod clamp around the rod, and tighten it securely against the pump rod.
    • Carefully lower the riser main and slider to allow it to rest on the rod clamp.
  10. Replacing Bush Pump Riser Main Slider: step 10, image 1 of 3 Replacing Bush Pump Riser Main Slider: step 10, image 2 of 3 Replacing Bush Pump Riser Main Slider: step 10, image 3 of 3
    • Loosen and remove both the pump rod jam nut and pump rod nut on the top of the slider.
  11. Replacing Bush Pump Riser Main Slider: step 11, image 1 of 2 Replacing Bush Pump Riser Main Slider: step 11, image 2 of 2
    • Remove the riser main slider, and inspect it for wear and tear.
    • Set the slider in a sanitary place to prevent contamination.
Jake Devincenzi
117,381 Reputation
57 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 183
