Introduction
This guide will walk you through the procedure to remove the above grade riser pipe. You can then replace it with a new one, or perform any necessary repairs on it.
Lift the slider and riser main pipe.
Place a pump rod clamp around the rod, and tighten it securely against the pump rod.
Carefully lower the riser main and slider to allow it to rest on the rod clamp.
Remove the riser main slider, and inspect it for wear and tear.
Set the slider in a sanitary place to prevent contamination.
Remove the above grade riser pipe.
Firmly screw a T-handle onto the pump rod.
