Introduction
The manufacturer told me by email that the device is not repairable. We are doing it anyway. The cost of a new better battery is about half the purchase value for a new lamp.
The housing has a waterproof ultrasonic weld. To open the housing, it must be sawed open or destroyed. Subsequently, it is glued back together so that it becomes watertight.
Busch + Müller Toplight 2C permanent
Saw the lamp along the ultrasonic welding seam with a fine saw (e.g. Japanese saw).
A total of four straight cuts must be made
Saw carefully so that the electronics or the battery do not get damaged
Pull the old battery out of the socket
The plug may be relatively tight in the socket. Simply wiggle it until it can be pulled out or use pliers
Under the black foil there are two Li-Io cells in AAA size.
At the two outer ends are the negative terminals, which are connected with a metal clip
Remove the round stickers and the long metal clip
Remove the cables including the socket
Buy 2x ICR10440 with solder tag
(The batteries used here are ICR10440; 3,7V each 320mAh with Z-solder tag)
Put the batteries with the positive side to each other and solder the lugs
Now solder the red connection cable
The outer solder lugs are soldered to the sheet metal (paper clip as soldering aid).
The black connection cable is also soldered to the sheet metal
Stick the yellow adhesive tape on the open contacts
Stick the circular red stickers on the outer positive terminals again
Fix the new battery pack with insulating tape.
Plug the power connector into the socket of the board
Insert the board into the black housing with the USB socket pointing downwards
Put on the reflector
To make the housing watertight again, the previously sawed seam must be glued together with a gap-filling adhesive. This can be done for example with Sikaflex
Apply glue carefully along the contour (e.g. Sikaflex)
Make sure that the LEDs and the switch remain clean.
Close the housing and let the glue harden.
Work through the steps in reverse order to reassemble your device.
Special thanks to these translators:
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
