Introduction
In this step we will be removing the rear casing from the sewing machine. This is necessary to access the inside components of the machine.
Place the machine on a solid surface.
Remove the 14mm Phillips #2 screw holding on the face cover.
Remove the two 14mm Phillips #2 screws and two 22mm Phillips #2 screws that secure the rear casing.
Lay the machine on its side.
Remove the four 10mm Phillips #2 screws that hold the bottom panel in place.
