Brother PT-D200 Cutter Blade Replacement
  1. Brother PT-D200 Cutter Blade Replacement, Cutter Blade: step 1, image 1 of 2 Brother PT-D200 Cutter Blade Replacement, Cutter Blade: step 1, image 2 of 2
    • Open the back panel of the device by pressing down on and then pulling the indication arrows on the top center of the cover upward towards you.
  2. Brother PT-D200 Cutter Blade Replacement: step 2, image 1 of 3 Brother PT-D200 Cutter Blade Replacement: step 2, image 2 of 3 Brother PT-D200 Cutter Blade Replacement: step 2, image 3 of 3
    • Locate the cutter blade unit (mint green) as shown in the picture.
  3. Brother PT-D200 Cutter Blade Replacement: step 3, image 1 of 2 Brother PT-D200 Cutter Blade Replacement: step 3, image 2 of 2
    • Using the thumb and forefinger, pull up, applying a moderate amount of pressure until the cutter blade unit loosens and is removed. Replace it with a new cutter blade unit until it snaps into place.
    • The blade is sharp.
Blaire McCreary
201 Reputation
2 Guides authored
Cal Poly, Team 13-16, Regan Winter 2014 Member of Cal Poly, Team 13-16, Regan Winter 2014
CPSU-REGAN-W14S13G16
3 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 40
All Time: 3,141
