Brother PT-210 Back Case Opening
    1. Brother PT-210 Back Case Opening, Back Cover: step 1, image 1 of 3 Brother PT-210 Back Case Opening, Back Cover: step 1, image 2 of 3 Brother PT-210 Back Case Opening, Back Cover: step 1, image 3 of 3
      • Use the tab to open the back cover of your machine.
      Ask FixBot
    1. Brother PT-210 Back Case Opening, Tape: step 2, image 1 of 2 Brother PT-210 Back Case Opening, Tape: step 2, image 2 of 2
      • Remove the tape by grabbing the tape and pulling it up & out of your machine.
      Ask FixBot
    2. Brother PT-210 Back Case Opening, New Tape: step 3, image 1 of 1
      • If you are going to use a new tape, you have to turn the green knob counterclockwise a few times to get the tape ready to use.
      Ask FixBot
    1. Brother PT-210 Back Case Opening, Batteries: step 4, image 1 of 3 Brother PT-210 Back Case Opening, Batteries: step 4, image 2 of 3 Brother PT-210 Back Case Opening, Batteries: step 4, image 3 of 3
      • Remove all 6 batteries from your machine.
      • When you put the batteries back in, keep in mind that the polarity of them matter. Your machine won't work if the polarities of the batteries are messed up.
      • Do not mix new and old batteries!
      • It might be helpful to take the tape out of your machine. This guide shows you how to.
      Ask FixBot
    1. Brother PT-210 Back Case Opening, Remove Screws: step 5, image 1 of 1
      Tool used on this step:
      Phillips #00 Screwdriver
      $5.49
      Buy
      • Remove these screws with a Phillips #00 Screwdriver.
      • Don't forget the sneaky ones!
      • When you are opening it, make sure to not damage any of the electronics inside.
      Ask FixBot
TheMasterG
1,430 Reputation
12 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 77
All Time: 346
