Introduction
This guide will show you how to take apart the back panel to replace the keypad contacts.
First: To separate the top cover from the body, insert a spudger between the two halves.
Gently twist the spudger until the two halves separate. Do this in multiple spots around the perimeter of the cover to distribute the pressure.
Gently grasp the ribbon wire and top cover, then gently pull the ribbon wire out of its connection.
Carefully pinch the top of the connector.
Pull perpendicular to the device until the wire is disconnected.
