Brother PT-110 Back Plate Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
3
Past 30 Days:
16
All Time:
198
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 - 15 minutes
Difficulty: Moderate
Prerequisite Only This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
In order to replace or repair the motors, gears, etc., the back plate has to be removed. Ensure the batteries are not in the device before starting this guide.
Tools
    1. Brother PT-110 Back Plate Replacement, Batteries: step 1, image 1 of 2 Brother PT-110 Back Plate Replacement, Batteries: step 1, image 2 of 2
      • Push on the side of the cover, and remove it.
      Ask FixBot
    2. Brother PT-110 Back Plate Replacement: step 2, image 1 of 1
      • Remove the batteries.
      Ask FixBot
    1. Brother PT-110 Back Plate Replacement, Back Plate: step 3, image 1 of 2 Brother PT-110 Back Plate Replacement, Back Plate: step 3, image 2 of 2
      • Remove the cartridge and the yellow tape cutter.
      • Unscrew the two 9 mm Phillips #1 screws from the top and bottom.
      • Total: 2 x Screws
      Ask FixBot
    2. Brother PT-110 Back Plate Replacement: step 4, image 1 of 1
      • First: To separate the top cover from the body, insert a spudger between the two halves.
      • Gently twist the spudger until the two halves separate. Do this in multiple spots around the perimeter of the cover to distribute the pressure.
      • DO NOT PULL HALVES APART. There are wired connections inside that must be disconnected before halves can be fully separated.
      • A small flat screwdriver works for this step. Use on the left and right sides.
      Ask FixBot
    3. Brother PT-110 Back Plate Replacement: step 5, image 1 of 1
      • Gently separate the two covers, ensuring wires are not taut.
      Ask FixBot
    4. Brother PT-110 Back Plate Replacement: step 6, image 1 of 1
      • Gently grasp the ribbon wire and top cover, then gently pull the ribbon wire out of its connection.
      Ask FixBot
    5. Brother PT-110 Back Plate Replacement: step 7, image 1 of 2 Brother PT-110 Back Plate Replacement: step 7, image 2 of 2
      • Carefully pinch the top of the connector.
      • Pull perpendicular to the device until the wire is disconnected. Remove the other connector by pulling it parallel to the circuit board.
      • It may require more force than expected to disconnect the wires.
      Ask FixBot
    6. Brother PT-110 Back Plate Replacement: step 8, image 1 of 3 Brother PT-110 Back Plate Replacement: step 8, image 2 of 3 Brother PT-110 Back Plate Replacement: step 8, image 3 of 3
      • Unscrew the three 9 mm Phillips #1 screws shown.
      • Total: 3 x Screws
      • Lift the metal plate upwards, don't unscrew the motor, this will remain attached to the plate. If you didn't remove the yellow tape cutter then it will simply fall out.
      Ask FixBot
Kimberly Larsen
291 Reputation
5 Guides authored
IUPUI, Team 1-1, Harley Fall 2016 Member of IUPUI, Team 1-1, Harley Fall 2016
IUPUI-HARLEY-F16S1G1
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 198
