Brother MFC-J4420DW opening procedure
  1. Brother MFC-J4420DW opening procedure, Removing hood holder: step 1, image 1 of 3 Brother MFC-J4420DW opening procedure, Removing hood holder: step 1, image 2 of 3 Brother MFC-J4420DW opening procedure, Removing hood holder: step 1, image 3 of 3
    • Disconnect the power cord of the printer
    • Open the printer as you would to access the USB port.
    • Pull out the rear end of the hood holder (see picture two). After that you can remove the top part of the hood holder.
    • Now remove the hood holder completely.
    • It is quite useful to put the printer near something so that you can lean the top against something, for example a wall.
  2. Brother MFC-J4420DW opening procedure, Removing cables connected to the top part of the printer: step 2, image 1 of 3 Brother MFC-J4420DW opening procedure, Removing cables connected to the top part of the printer: step 2, image 2 of 3 Brother MFC-J4420DW opening procedure, Removing cables connected to the top part of the printer: step 2, image 3 of 3
    • Next remove the cover on the left side of the printer (lift the right side of the cover first).
    • Unplug the black ribbon cable, the blue and the white plugs from its sockets and unscrew the cable which is attached with a screw (see second image)
    • Remove the red and white plugs from its sockets as shown in picture three.
  3. Brother MFC-J4420DW opening procedure, Remove the top part of the printer: step 3, image 1 of 3 Brother MFC-J4420DW opening procedure, Remove the top part of the printer: step 3, image 2 of 3 Brother MFC-J4420DW opening procedure, Remove the top part of the printer: step 3, image 3 of 3
    • Flip the plastic part shown in picture one up to the top part of the printer
    • Now you can easily remove the top of the printer by pushing it away from the printer (not up).
  4. Brother MFC-J4420DW opening procedure, Remove cover: step 4, image 1 of 2 Brother MFC-J4420DW opening procedure, Remove cover: step 4, image 2 of 2
    • Remove the screws connecting the black plastic cover to the printer (see image)
    • Remove the cover
Finish Line
Matthias Loikasek
1,373 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 110
All Time: 1,658
