Brother CS6000i Needle Plate Replacement
    1. Brother CS6000i Needle Plate Replacement, Body: step 1, image 1 of 2 Brother CS6000i Needle Plate Replacement, Body: step 1, image 2 of 2
      • Remove the five 20 mm Phillips #2 screws on the back of the device.
      • Remove the single 28 mm Phillips #2 screw on the back of the device.
      • Remove the single 23 mm Phillips #2 screw on the back of the device.
      Ask FixBot
    2. Brother CS6000i Needle Plate Replacement: step 2, image 1 of 2 Brother CS6000i Needle Plate Replacement: step 2, image 2 of 2
      • Pull the white cover off.
      Ask FixBot
    3. Brother CS6000i Needle Plate Replacement: step 3, image 1 of 2 Brother CS6000i Needle Plate Replacement: step 3, image 2 of 2
      • Remove the final screw, a 11 mm Phillips #2.
      • After removing all eight screws, you will have five 2 mm screws, one 28 mm screw, one 23 mm screw, and one 11 mm screw, all of which are Phillips #2.
      Ask FixBot
    4. Brother CS6000i Needle Plate Replacement: step 4, image 1 of 3 Brother CS6000i Needle Plate Replacement: step 4, image 2 of 3 Brother CS6000i Needle Plate Replacement: step 4, image 3 of 3
      • Slightly pull apart the two halves of the machine, taking care not to strain the attached cables.
      • Unhook the white wires that are connected to the motherboard.
      • Fully separate the two halves.
      Ask FixBot
    1. Brother CS6000i Needle Plate Replacement, Needle Plate: step 5, image 1 of 2 Brother CS6000i Needle Plate Replacement, Needle Plate: step 5, image 2 of 2
      • Remove the two screws securing the needle plate with a 4mm flathead screwdriver.
      Ask FixBot
Ava Martinez
448 Reputation
4 Guides authored
Cuesta, Team 20-1, Krynen Fall 2024 Member of Cuesta, Team 20-1, Krynen Fall 2024
CUESTA-KRYNEN-F24S20G1
5 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 27
Past 30 Days: 75
All Time: 530
