Introduction
This guide will take you through the process of properly removing the motherboard of the device. Removal of the motherboard is necessary to access additional components that may need fixing.
Remove three 8mm screws from the left side of the device.
Remove four 8mm screws from the right side of the device.
Press down on the top cover of the device and slid it towards you until you see a slight gap created.
Lift the top cover off.
Slide the body case back away from the bottom.
Pull up the body case to remove it from the bottom.
Remove each of the four 8mm silver screws located at each corner of the motherboard with a J0 bit screw driver.
