Briefcase Strap Holder Replacement
Views: 1K
View statistics:
Past 24 Hours:
5
Past 7 Days:
54
Past 30 Days:
141
All Time:
1,010
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide shows how to repair the strap holder of a briefcase. It is designed to fix loose or damaged bag strap holders, as well as any bag with a strap holder.
This guide provides a quick and safe way to repair or strengthen the straps of your briefcase. It is an easy-to-install design and a fast-fastening strap holder to ensure durability and stability, extending the life of your briefcase. Whether you're dealing with a broken buckle, worn bag straps, or need to strengthen an existing bag strap, this guide offers seamless repairs without expensive repairs or replacements.
This guide uses a sewing machine and hot glue; if you have sewing skills, it is perfect for you.
    1. Briefcase Strap Holder Replacement, Strap Holder: step 1, image 1 of 1
      • Cut the whole old strap holder from the bag.
      • If the strap holder breaks in other parts, cut it all out.
      Ask FixBot
    2. Briefcase Strap Holder Replacement: step 2, image 1 of 2 Briefcase Strap Holder Replacement: step 2, image 2 of 2
      • Draw a longer shape of the strap holder with a pencil on another piece of fabric.
      • Both extensions should be the same length, at least 1/4 to 1/2inch long.
      Ask FixBot
    3. Briefcase Strap Holder Replacement: step 3, image 1 of 1
      • Cut the piece of fabric.
      Ask FixBot
    4. Briefcase Strap Holder Replacement: step 4, image 1 of 2 Briefcase Strap Holder Replacement: step 4, image 2 of 2
      • Add glue in the center of the new piece of fabric.
      • Glue the strap holder on in the center and leave the same length on both sides.
      • You can also use a glue gun.
      Ask FixBot
    5. Briefcase Strap Holder Replacement: step 5, image 1 of 2 Briefcase Strap Holder Replacement: step 5, image 2 of 2
      • Use a sewing machine to sew the strap holder with the glued piece of fabric in the center.
      • If you have good sewing skills, you can sew on both sides.
      Ask FixBot
    6. Briefcase Strap Holder Replacement: step 6, image 1 of 2 Briefcase Strap Holder Replacement: step 6, image 2 of 2
      • Place the metal strap holder between the leather strap holder and fold it.
      • Use the sewing machine to sew the tips of the fabric that was glued on the leather strap holder.
      • If your metal strap holder is openable, sew without the metal strap holder.
      Ask FixBot
    7. Briefcase Strap Holder Replacement: step 7, image 1 of 2 Briefcase Strap Holder Replacement: step 7, image 2 of 2
      • Add more glue between the fabric and the leather strap holder to strengthen it and hold it while it dries.
      Ask FixBot
    8. Briefcase Strap Holder Replacement: step 8, image 1 of 1
      • Trim the area where the strap holder is placed.
      Ask FixBot
    9. Briefcase Strap Holder Replacement: step 9, image 1 of 3 Briefcase Strap Holder Replacement: step 9, image 2 of 3 Briefcase Strap Holder Replacement: step 9, image 3 of 3
      • Add glue with a glue gun to the area where the strap holder is placed.
      • Place the strap holder in the strap holder area of the bag and hold it while it dries.
      • It is recommended to sew the strap holder fabric to the area where it will be placed.
      Ask FixBot
Finish Line
Hao Yi Michelle Lu
169 Reputation
1 Guide authored
UC Davis, Team 1-8, Vidal-Chiesa Fall 2024 Member of UC Davis, Team 1-8, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S1G8
2 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 54
Past 30 Days: 141
All Time: 1,010
