Introduction
The shaver had to be recharged at increasingly shorter intervals after a few years. This type of shaver can also be operated on the power cord if necessary. After replacing the two batteries, it now runs 2-3 weeks with daily shaving. The batteries should be provided with pins on both poles (+-), because they sit so better in the clamps. Alternatively, batteries with normal contacts can be used, but the clamps must be strongly bent so that they give a secure contact.
Pull off the shaving head.
Squeeze the clamp springs with tweezers to easily remove the vibrator pins and their springs.
Take off the third pin at the same time.
Unscrew the two torx screws and remove the cover plate, make sure not to lose the 2 sealing rings (under the plate, now not visible)!!!
Then remove the two sealing membranes.
Pull off the housing head. Some force will be required for that
pay close attention to the sealing rings!
Remove the vibrator head, paying attention to the "nose" that must be fitted when installing in the beard trimmer!
Carefully pry open the flexible cover at the marked points (also on the back) with a suitable tool. Caution: the tabs bend easily and may break off.
Flip the metal switch up,
then carefully pry the electronics board out of the holders and
swap the batteries.
Good luck with the assembly!
Work through the steps in reverse order to reassemble your device.
8 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
