Introduction
Symptom: the Multimix is running fine without load, it can easily be stopped by hand and following a gentle squeaking is noticeable.
Cause is most likely a broken sprocket on the motor shaft.
To repair either a new set of wheels can be installed or the main sprocket can be tried to be glued
Put the device head over
Lift the cover on the rear end (maybe add another spudge to lift a bit more)
Push the cover to the rear end (cord inlet)
Lift from the side of the cover and remove cover.
Remove PH2 screw
With one or more spudgers lift the back cover slightly
With a small screwdriver push in the middle of the cover to release the nose (see pic 3)
After opening the case, remove the motor and electronics from the casing. It might be helpful to press the release button (green part).
Follow the instructions in reverse order to reassemble the device
Special thanks to these translators:
100%
Chris is helping us fix the world! Want to contribute?
Start translating ›
