Introduction
How to open the casing of the Braun Multimix 280W, either to continue disassembling (e.g. change gears) or just fix a broken cord.
Needed tools:
- Spiegel or plastic card
- philips #2, PH2 screwdriver
- small screwdriver
- T10 Torx screwdriver
Put the device head over
Lift the cover on the rear end (maybe add another spudge to lift a bit more)
Push the cover to the rear end (cord inlet)
Lift from the side of the cover and remove cover.
Remove PH2 screw
With one or more spudgers lift the back cover slightly
With a small screwdriver push in the middle of the cover to release the nose (see pic 3)
Go in reverse order do assemble the devicd
3 other people completed this guide.
Special thanks to these translators:
100%
Chris is helping us fix the world! Want to contribute?
Start translating ›
4 Guide Comments
I fixed my non functional switch by splitting the mixer as shown here. Sliding out the pcb with the maroon colored switch unit. Pried open the switch housing, careful to catch the ball bearings and springs. Then cleaning the contact pads in the rear of the switch, bending down the brass shims a bit more to make sure they hit the pads, putting silicone grease on top and bottom of the housing where the ball bearings go and snapping it back together.
one spring goes in the front of the slider, one spring goes in the hole top to bottom of the switch, with a ball bearing on each end of the spring top to bottom spring, use the grease to hold one of the bb in place while snapping back together.
Before I fixed it, only the forward pulse option worked.
Hi my multimix work but if something so strong stack and don’t work just make sound how can I fix it . It happened when use blender mode
