Braun Aromaster KF440 Base Replacement
  1. Braun Aromaster KF440 Base Replacement, Access the base: step 1, image 1 of 1
    • Remove the carafe (coffee pot) from the coffee maker.
    • Turn the Braun Aromaster KF 440 upside down so the base is exposed.
  2. Braun Aromaster KF440 Base Replacement, Remove the nut: step 2, image 1 of 1
    • Locate the nut at the center of the base and unscrew it with a pair of basic pliers.
  3. Braun Aromaster KF440 Base Replacement, Remove the cover: step 3, image 1 of 1
    • Gently lift the cover away from the bottom of the coffee maker and remove it.
Darcy Groom
343 Reputation
3 Guides authored
Baylor, Team 8-12, Williams Fall 2014 Member of Baylor, Team 8-12, Williams Fall 2014
BU-WILLIAMS-F14S8G12
3 Members
10 Guides authored
2 Comments
Can’t remove nut. Soooo small. Plus, clockwise… Or counter clockwise?
Bobbie Savitz - Reply
Das Problem istnicht die das Entfernen der Mutter wie beschrieben, sondern die Schraube die nur mit einem Spezial-Schraubenzieher geloesst werden kann. Und den gibts nicht zu kaufen. Oder?
Udo Doerge - Reply
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 23
All Time: 3,085
