Bralette Foam Insert Replacement
    1. Bralette Foam Insert Replacement, Foam Inserts: step 1, image 1 of 1
      • Lay out the bralette in a clean and flat place.
      Ask FixBot
    2. Bralette Foam Insert Replacement: step 2, image 1 of 1
      • Find the foam insert pockets.
      • These are usually found in the cups or sides of the bralette.
      Ask FixBot
    3. Bralette Foam Insert Replacement: step 3, image 1 of 1
      • Take out the existing foam inserts by carefully pulling them from their pockets.
      Ask FixBot
    4. Bralette Foam Insert Replacement: step 4, image 1 of 1
      • Use a lint roller to remove lint or dirt in the pockets.
      Ask FixBot
    5. Bralette Foam Insert Replacement: step 5, image 1 of 1
      • Select the right roam inserts that have the perfect size and thickness for the bralette.
      Ask FixBot
    6. Bralette Foam Insert Replacement: step 6, image 1 of 2 Bralette Foam Insert Replacement: step 6, image 2 of 2
      • Slide the replacement foam insert into the pocket of the bralette.
      • Make sure no bumps are present.
      Ask FixBot
    7. Bralette Foam Insert Replacement: step 7, image 1 of 1
      • Once inserted, make sure the foam inserts are in the correct place and give the ideal shape and support.
      Ask FixBot
    8. Bralette Foam Insert Replacement: step 8, image 1 of 1
      • Put the bralette on to check the shape and support of the replacement foam inserts.
      • Make any improvements if required.
      Ask FixBot
You did it! You have replaced your old foam inserts to revamp your favourite bralette.
Tasnuva Bushra
157 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 50
All Time: 527
