Shop the Holiday Gift Guide
Bottom Plate Removal
Views: 1.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
24
Past 30 Days:
107
All Time:
1,254
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
    1. Bottom Plate Removal, Remove back cover: step 1, image 1 of 1
      • Push down on the screw to depress the spring loaded hinge and release the door.
      Ask FixBot
    2. Bottom Plate Removal, Remove bottom cover: step 2, image 1 of 1
      • Remove six 5.3 mm #00 screws.
      • Remove one 3.4 mm #00 screw.
      • The short screw has a machine thread and screws into the plate underneath. The rest screw into the plastic body.
      Ask FixBot
    3. Bottom Plate Removal, Remove left front cover: step 3, image 1 of 1
      • Remove three 5.3 mm #00 screws (the bottom-most screw is not always present).
      • Remove one 7.3 mm #00 screw.
      • Remove the remote trigger cover.
      Ask FixBot
    4. Bottom Plate Removal, Remove front cover: step 4, image 1 of 2 Bottom Plate Removal, Remove front cover: step 4, image 2 of 2
      • Remove two 5.3 mm #00 screw.
      • Gently lift up on the flash housing to help remove the cover if necessary.
      Ask FixBot
    5. Bottom Plate Removal, Remove right front cover: step 5, image 1 of 1
      • Remove two 3.9 mm #00 screws.
      Ask FixBot
    1. Bottom Plate Removal, Prepare bottom plate: step 6, image 1 of 2 Bottom Plate Removal, Prepare bottom plate: step 6, image 2 of 2
      • Remove two 3.4 mm #00 screws. Remove the plate holding the contacts in place.
      • Peel tape from the plate. Leave the tape attached to the flex circuit.
      • Remove the flex circuits from their retaining studs.
      Ask FixBot
    2. Bottom Plate Removal, Remove bottom plate: step 7, image 1 of 2 Bottom Plate Removal, Remove bottom plate: step 7, image 2 of 2
      • Remove one 3.3 mm #0 countersunk screw.
      • Remove one 3.9 mm #0 shoulder screw.
      • Remove four 3.3 mm #00 screws.
      • Pull a little slack through the housing on this flex cable.
      • Pop the plate off its posts, rotate slightly clockwise and pull gently through the loosened flex cable.
      • To the camera tech that left me a happy little note...I see you.
      Ask FixBot
    3. Bottom Plate Removal, Remove transport gears: step 8, image 1 of 2 Bottom Plate Removal, Remove transport gears: step 8, image 2 of 2
      • It's best to remove these parts now so they don't fall out later on in the repair.
      Ask FixBot
Author
with
Sam Gustafson
14,878 Reputation
78 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 107
All Time: 1,254
