Remove the (6) six 1.5 cm Phillips screws holding on the bottom cover of the speaker using a Phillips #0 screwdriver.
Lift the cover straight up and set the cover to the side.
Remove the (2) two 1.5 cm screws circled in picture one.
Rotate the speaker to its side and remove the (2) two 1.5 cm screws circled in picture 2. Remove these screws on either side of the speaker.
After all screws are removed, gently remove the cover from the speaker as shown in picture 3.
After lifting the cover, you will see two ribbons attaching the cover to the speaker. Gently remove these ribbons by pulling straight down.
If i want to oder a new cable what cable and pins i should order, if you know details please send me details to j_ramana@yahoo.com
Using a metal spudger or a prying tool, gently push forward to separate the cover from the speaker.
4 other people completed this guide.
2 Comments
hi, where can we find the speakers?
Hi, where can i find the speaker
