Shop the Holiday Gift Guide
Bose SoundTouch 10 Front Panel Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
3
Past 30 Days:
13
All Time:
173
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
If the front mesh is dirty on your Bose SoundTouch 10, the front panel may need to be removed for cleaning with a fine bristle brush or compressed air.
You may also need to remove the front panel for access to parts inside the speaker that may need to be replaced.
Tools
    1. Bose SoundTouch 10 Front Panel Replacement, Front Panel: step 1, image 1 of 1
      • Turn the speaker over so that the rubber strips along the bottom are facing you.
      • Use the iFixit Opening Tool to peel back the rubber strip on the bottom-front edge.
      Ask FixBot
    2. Bose SoundTouch 10 Front Panel Replacement: step 2, image 1 of 1
      • Use a #2 Phillips screwdriver to remove each of the three 20mm screws on the bottom front edge of the speaker.
      Ask FixBot
    3. Bose SoundTouch 10 Front Panel Replacement: step 3, image 1 of 2 Bose SoundTouch 10 Front Panel Replacement: step 3, image 2 of 2
      • Slide the front panel with the mesh covering downwards to disconnect it from the SoundTouch 10 body.
      • Lift the panel away to reveal the speaker head.
      Ask FixBot
Author
with
James Asbury
952 Reputation
5 Guides authored
Cal Poly, Team S13-G1, Forte Spring 2017 Member of Cal Poly, Team S13-G1, Forte Spring 2017
CPSU-FORTE-S17S13G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 13
All Time: 173
