You're viewing a previously published version of this guide. View latest version
The battery is located on the bottom of the speaker underneath a rubber protective cover. Use this guide to replace a faulty battery in your SoundLink Mini. Check what model battery your your SoundLink Mini has before purchasing a replacement.
Peel back the rubber battery cover and remove the four circled 6.0 mm screws using a T8 Torx Screwdriver.
While holding the cover back, pull straight up on the battery to remove it.
with 6 other contributors
1,849 Reputation
1 Guide authored
Badges: 15
+12 more badges
CPSU-MANESS-F15S1G23
4 Members
21 Guides authored
Choose a size and copy the code below to embed this guide as a small widget on your site / forum.
Past 24 Hours: 20
Past 7 Days: 155
Past 30 Days: 715
All Time: 245,405
